YotaTech saved me $$$$$$$
I'll make it quick.
My 99 all of a sudden started losing power and running really rough. Very low idle, no acceleration, just running like crap. So as always I hit the search button here and typed in "rough idle". So a bunch of info came up along with the no brainers:
-bad gas
-hose leak
-fuel filter
-clogged injectors
-plugs
-wires
-dirty MAF
-IAC
You get the picture. so I went down the checklist hoping it wasn't an o2 sensor or a bad MAF sensor. I'm just broke. Started with the gas-two cans of seafoam- and 91 octane. No change. Cleaned MAF. No change. Got to the plugs and *BINGO* I pulled the second plug out and it had no electrode! WTF!!
Probably not the best for my engine,but nothing I can do 'bout that. Changed the rest of the plugs and for the hell of it dumped 1/3 of a can of seafoam thru the PCV hose. Smoked out the neighborhood! But after 5min of that engine ran awesome. Not only was the problem solved but with the Seafoam it smoother, more responsive, and quieter than ever. Cool stuff. Anyways thanks fellas!
-bad gas
-hose leak
-fuel filter
-clogged injectors
-plugs
-wires
-dirty MAF
-IAC
Probably not the best for my engine,but nothing I can do 'bout that. Changed the rest of the plugs and for the hell of it dumped 1/3 of a can of seafoam thru the PCV hose. Smoked out the neighborhood! But after 5min of that engine ran awesome. Not only was the problem solved but with the Seafoam it smoother, more responsive, and quieter than ever. Cool stuff. Anyways thanks fellas!-
Plugs ar the #1 suspect.
Man,
Keep on "rocking in the free world!!!
Just kidding
good job, I had the same issue as you. Plugs are real important, wrote the post : " #1 SUSPECT: spark Plug gaps as WIDE as ...."
Check it out tell me what you think,
good work
Just kidding
good work
Jun 1, 2021 01:51 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
Jan 16, 2016 06:38 PM
crashburnoveride
Jul 10, 2015 06:39 AM
