XM radio prople or radio installers
Old Feb 27, 2004 | 07:17 AM
Citykid's Avatar
My connection diagram says I need to attach one wire to "a terminal always supplied with power regardless of ignition switch position." Can anyone help me out here with a suggestion of where I should attach this wire? Thank you.
Old Feb 27, 2004 | 07:48 AM
Scottiac's Avatar
under your dash, there should be two labelled connection points, one labelled 12V, one labelled ignition. The 12V one should be what you want.
At least that was what was on my '97. It was right in front of the steering column once you removed that panel...
Old Feb 27, 2004 | 08:51 AM
SLC Punk's Avatar
For my Sirius system, I ran the wire directly to the battery.
Old Feb 27, 2004 | 09:02 AM
Citykid's Avatar
I was thinking of tapping into the supply wire for the radio. This is so your presets aren't lost everytime.
Old Feb 27, 2004 | 10:14 AM
Scottiac's Avatar
All of the above would work just fine!
(make sure you get the right power line to the radio; it uses both the 12v and the ignition on different wires).
What I did was to add two fuse boxes in the engine bay, one always hot, one on the ignition, but if you aren't adding several things, that's an unnecessary pain in the hindquarters...
Old Feb 28, 2004 | 08:56 PM
Duffdog's Avatar
when you take out the radio....the wire that is 12v all the time is the blue/yellow--- or to the ignition switch, its solid white. use a t-tap or something so that you dont lose the coding on the radio and have to unlock it if you cut the wire.
t
Old Feb 29, 2004 | 02:04 PM
Citykid's Avatar
I have an aftermarket radio & wiring harness form Crutchfield. I just called them up and they told me which color wire is which.
Yellow - constant power
Red - switched power
Old Feb 29, 2004 | 05:08 PM
Duffdog's Avatar
wtf...! i was talking about the wires from the car...not the metra harness, obviously if you have a harness, then you have the mecp colors right there.
t
jasonty
41
Dec 23, 2018 01:00 PM
Mrhoadley
Aug 4, 2015 06:08 PM
Yota.Jay
Jul 26, 2015 05:50 PM
TDonkey
Jul 26, 2015 10:14 AM
mtb_taco
Jul 15, 2015 08:36 AM
