Wrong tire and rim - need help!!!
Old Feb 22, 2005 | 02:26 PM
TBob's Avatar
Put 285/75/16 on my 03 taco and I'm rubbing the frame. The rims are 16 x 8 with 3.75" BS - I would have thought that would have cleared - I was wrong!
Anyhow I need to figure out what to run, Discount is willing to do whatever I want to fix it but I need to decide tonight.
If I need a rim with more BS - suggestion?
I thought I would swap them out with 255/85/16 but I would have to go to BFG MT's - not sure how thrilled I am about that.
How about the steering- is there an adjustable stop?
Thanks!!
TBob
Old Feb 22, 2005 | 03:00 PM
socal98runner's Avatar
What tires did you get? Are you sure it's a 3.75 BS?
Swap me for my 265/75/16's!!
Old Feb 22, 2005 | 03:01 PM
FilthyRich's Avatar
Thanks!!
TBob
keep the tires., lift your truck
Old Feb 22, 2005 | 03:02 PM
FilthyRich's Avatar
no lift =, then a 265/75 will be slightly larger and you won't have major rubbing issues.
Old Feb 22, 2005 | 03:22 PM
TBob's Avatar
I'm lifted - 2" BL the tires are rubbing the frame - not the fender well
Old Feb 22, 2005 | 03:35 PM
Darren's Avatar
More backspacing should help. I don't know how similar those are compared to 4Runners, but I'm guessing pretty close. 4.25" is likely ideal, but 4" should still work better than what you have. You may very well still rub, but it should be minimal. 7" wheels would be better yet, but that doesn't sound like what you're wanting to do.
Old Feb 22, 2005 | 03:47 PM
FilthyRich's Avatar
ditto
Old Feb 22, 2005 | 04:04 PM
TBob's Avatar
yahoo!! fixed!
Well turns out it wasn't rubbing on frame it was the back of the front fender just had to trim alot more pastic and hammer a little more - problem solved
Jun 1, 2021 01:51 PM
chukarhunt
Dec 8, 2019 11:39 AM
82yodahickman
34
May 16, 2017 01:00 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
Yotoder865
Jul 9, 2015 07:51 PM
