wont start
Old Aug 16, 2003 | 10:08 PM
headhunter's Avatar
wont start
i have basically the same problem as hammerdown6 had
1. Have fuel at the fuel rail and fuel filter (havent checked yet ) where are they
2. Battery OK
3. Starter OK
4. Fuses in driver's kick panel OK
5. there is spark at the plugs
6. havent checked as of yet Jumped TE1 & E1 at Diag. conn. Check engine light flashes code "1" - all OK ( is this the same for 87 4runner with 22re 4cyl)
7. Cap & rotor replaced
8. new Plug wires
9. plugs - new
10. Timing belt at least intact
11. fuel pump wont run (with hot wire it works but still wont start
Old Aug 17, 2003 | 04:56 AM
HammerDown6's Avatar
Found some info that might help you out. It's PDF so you'll need Adobe Acrobat to view it.
www.net-impress.com/4runner/cd/F_BASIC2.PDF
If that link doesn't work, do a search for "4Runner Coil problem" and look for the link that says, "F - Basic testing - 3.0".
Old Aug 17, 2003 | 07:22 AM
headhunter's Avatar
wont start
would all these tests be the same for 87 4runner with 22re (4cyl)
thanks for the info by the by
Old Aug 17, 2003 | 12:21 PM
headhunter's Avatar
i have 6 flashes when i cross those 2 leads te1-e1
any help
Old Aug 17, 2003 | 03:24 PM
According to Haynes, 6 blinks = RPM Signal with possible trouble areas of:
1. Igniter circuit
2. Igniter
3. Distributor
4. Computer
I am not aware of a test for the igniter.
Old Aug 17, 2003 | 05:23 PM
headhunter's Avatar
hey hammerdown6 do you know of a way to check the computer. i tried the one out of the 88 and it does the exact same thing and that one seems to have been replaced.
Old Aug 18, 2003 | 07:23 AM
Denk's Avatar
MAke sure to test yer air sensor.....
Old Feb 2, 2004 | 07:56 AM
Rincontrx650's Avatar
Hi all, I am having the same problem ans same symptoms as Headhunter, i've tested the efi main relay, open circuit relay.
I have nice spark at the plugs but nothing coming from the igniter plug with the three wires that feed the ECU, ie. the black and red, black and white and black and yellow. I notice thta there is no pulse at the injectors and from looking at the schematic on all data I see that the black and red seems to feed the injectors I may be wrong.
My question is should i get any voltage coming out of the igniter plug when the key is on and when the engine is cranking over? I am not clear on this one.
The cold start timing switch and injector check out fine and the engine starts just momentarily from the small amount coming from the cold start injector. Any help or ideas would be appreciated.
Thanks TC.
88 4 runner bush buggy
87 4 runner great shape dont run.
Old Feb 2, 2004 | 03:10 PM
Man, is this an old thread.
The problem turned out to be the ignition coil. I checked the secondary voltage against spec, and it was way out. Replaced the coil and she fired up instantly.
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
