Wolo Air Horns Installation???
Old Mar 21, 2004 | 11:47 AM
AKA.HULK's Avatar
Question Wolo Air Horns Installation???
Hi all. Need some help. I just installed the Wolo 402 air horns on my 2003 4Runner but they are not working. I followed the instructions given to me from Wolo tech. department. This is my installation per there instructions. If any one sees anything I might of did wrong, please advise.
1. Connect the negative of the compressor to the neg. of the battery terminal. (8 Gauge Wire)
2. Connect the postive of the compressor to #87 from the relay switch. (8 Gauge wire)
3. Connect #30 from the relay to the positive of the battery using 8 gauge wire with an inline 25amp fuse I got from the stereo place I always use.
4. Connect #85 & #86 from the relay to the two wires from the origianl horn. I taped up the wire from the right horn because I was told it was not needed. I use the two wires from the left horn as per instructions given to me. (16 Gauge Wires)
There is also some type of plug that has two wires and comes from the same gromet as the horn wires. It is a sealed piece. I was wondering if it has anything to do with the horns and if maybe these are the wires that I have to use. I checked my connections and all seems secure. Does anyone have any idea what might be the problem? Thanks
Old Mar 21, 2004 | 09:12 PM
Brendan's Avatar
it's gotta be your 85 or 86 connections on the relay. 85 can go straight to ground. 86 should be the hot (+) terminal. the compressor can ground straight to bare metal as well. perhaps your fuse blew? I use 30A fuses on my horns.
Old Mar 23, 2004 | 03:25 AM
AKA.HULK's Avatar
I checked what you told me and found that #85 is (+) and #86 is (-). After making the switch, I HAVE HORNS . I'll be calling Wolo Tech. later today to complain about there so so installation instuctions. Thanks for the help.
MO transplant
Apr 23, 2023 11:58 AM
coryc85
Sep 9, 2015 06:24 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
terminator
Jul 27, 2015 07:13 PM
