Will a 83 tranny fit a 90?
Old Jan 29, 2003 | 08:35 AM
trailguide's Avatar
Angry Will a 83 tranny fit a 90?
In search of the answer. My 90 tranny is out . It goes into gear and drives but make terrible noises in neutral and in every gear but 4th. Metal chunks in the oil. Anyways will these trannys swap out? Both 4x4, 4cyl, 5-speed. Thanks for any help!
Old Jan 29, 2003 | 09:54 AM
growinseed's Avatar
If I remember right the 22R block height changed by a few cm. in late 84 early 85?. But if you can find a bell housing that bolts up to the '90 motor and the '83 trannny you should be in luck. I'm sure if you call Tim @ DOAracing, he will give you all the specifics.
Good luck
Nathan
Old Jan 29, 2003 | 10:55 AM
94 First Responder's Avatar
The 81-83 trannys are pretty weak. I wouldnt go that old. 82 was the first year for 5spd too and the org 5th was terrible so I would stay away from those years.
Old Jan 29, 2003 | 06:49 PM
Fahrenheit 451's Avatar
Even if you could get them to mate up, you don't want to do it. The bearing around the input shaft on the '83's were weak and when they go out they go out bigtime and wash throughout the transmission saying goodbye to all the other parts as they pass by.
Go here http://www.marlincrawler.com/trans.html and check out what they have to offer. From the chart, it appears that the '83 might not fit anyway.
I wish they had an adapter to make the r150f fit the old 22re. I think you have to change the input shaft and flywheel though. If you could, you get get a lower get set for the tranny. All it takes is $, and $ and $ and $....
BeMiceElf
Oct 10, 2015 09:40 PM
old87yota
Sep 9, 2015 12:39 PM
bootscootboogie
Sep 5, 2015 05:57 AM
yourrealdad
Jul 29, 2015 11:08 AM
Iceman4193
Jul 15, 2015 04:48 PM
