Old Mar 11, 2016, 03:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
Print Wikipost
Will 285/75R16 tires fit? 3rd gen 4runner stock?
Old Aug 28, 2007 | 02:42 PM
Rays94runner's Avatar
Somebody has this size for sale and I was wondering how they would fit my 97 4runner. I current have 265/75 r16. I dont really know how the sizes work. I dont really want them if they're going to rub alot. Thanks for any advice Ray
Old Aug 28, 2007 | 02:48 PM
1999runner's Avatar
no they will rub alot
Old Aug 28, 2007 | 02:50 PM
terryjmatthew's Avatar
They will rub like an undersexed monkey.
Old Aug 28, 2007 | 02:57 PM
Sloan's Avatar
so does 265/75/16 rub on a factory size 4runner? i was told by someone it does and someone else i need a small lift to do it...
Old Aug 28, 2007 | 02:58 PM
4biker's Avatar
Noooooooooooooooooooooooooo!!!
Seriously,
Do a search on tire size, and 3rd gen is the most asked about for this topic.
Old Aug 28, 2007 | 03:31 PM
flyfishexpert's Avatar
265/75 will not rub
If you want to go with a larger tire you could always look at 255/85r16. Click here to see what Expeditions West did.
But seriously, there is a ton of information on this forum regarding tire size and amount of lift required. Do a quick search and you will find more information and opinions than you can shake a stick at.
Old Aug 28, 2007 | 04:11 PM
tntempest's Avatar
275/70/16's don't even come close to rubbing either, and wont mess with your speedo as much.
Old Aug 28, 2007 | 04:28 PM
HuskyRunner's Avatar
Originally Posted by flyfishexpert
265/75 will not rub
Awesome tire size (except it confuses tire salesmen - they kept correcting me, they thought I wanted 285/75's), but you do need at least a 2" body lift and trimming. Check this out for more info https://www.yotatech.com/forums/f2/n...e-room-109575/
Old Aug 28, 2007 | 05:06 PM
265/75R16's rubbed slightly on my stock 01 w/ running boards.
Old Aug 28, 2007 | 05:12 PM
As far as I know, you'll be okay with 265/75's on a '97. 00-on 4runners sat slightly lower, so may have more rubbing issues. Just to be safe though, check out the actual measurements of any tires you're looking at - they vary widely, even within a "size"
Old Aug 28, 2007 | 05:53 PM
frodin1's Avatar
I have 285 BFG AT's, I started out with a 2.5" Daystar spacer lift and very little trimming. The very inside of the running board needed to be cut about a half inch, which was easily done with a razor knife. I now have the Tundra/OME lift and I've got good clearence. So you will need at least a 2.5" inch lift to make them clear any SERIOUS rubbing issues.
Old Aug 28, 2007 | 06:17 PM
crolison's Avatar
265-75-r16 for me only rub on my messed up valence. Everything else is fine.
Old Aug 28, 2007 | 06:36 PM
Sloan's Avatar
i always figured that the 00-02 models sat up hire then the earlier 3rd gens.
Old Aug 28, 2007 | 07:01 PM
moabite's Avatar
Stock '97
I have two stock '97's with 265/75R16. No problems at all.
Old Aug 28, 2007 | 07:16 PM
xcmountain80's Avatar
I dunno but 285 Interco SSR's sure as hell wont they measure out to 33.9" diameter.
Aaron
Old Aug 28, 2007 | 07:45 PM
neliconcept's Avatar
00s did, 01-02s are the lowest of the group, go sit next to a 99, you'll think its lifted.
put your truck next to mine, youll think im SASed
Old Aug 28, 2007 | 07:50 PM
Sloan's Avatar
so if i get this tire/rim package i been looking at for awhile...
265/75R16 Radial MTZ, 16x8 Dick Cepek DC-1 $1276.99
and remove the running boards i should be good?
Old Aug 28, 2007 | 08:00 PM
seanz0rz's Avatar
Guest
to OP: hey fellow pomona person!
the 285/75r16's will fit on your stock 6 spoke wheels, but they will rub the UCA's in front, thats why i had to buy new wheels with a different back spacing.
i wish i had stuck with the 265/75r16.
Old Aug 28, 2007 | 08:03 PM
i ran 16x7 wheels and 265/75/16 mtrs on my 4runner without running boards, however i rubbed at full lock going over a small bump, id get a one inch lift or body lift.
Old Aug 28, 2007 | 08:26 PM
Sloan's Avatar
dang, looks like ill just stick to 265/70/16 on my old factory rims...
