Will 285/75R16 tires fit? 3rd gen 4runner stock?
Somebody has this size for sale and I was wondering how they would fit my 97 4runner. I current have 265/75 r16. I dont really know how the sizes work. I dont really want them if they're going to rub alot. Thanks for any advice Ray
no they will rub alot
They will rub like an undersexed monkey.
so does 265/75/16 rub on a factory size 4runner? i was told by someone it does and someone else i need a small lift to do it...
Originally Posted by terryjmatthew
(Post 50603333)
Seriously, Do a search on tire size, and 3rd gen is the most asked about for this topic. |
Originally Posted by Sloan
(Post 50603337)
If you want to go with a larger tire you could always look at 255/85r16. Click here to see what Expeditions West did. But seriously, there is a ton of information on this forum regarding tire size and amount of lift required. Do a quick search and you will find more information and opinions than you can shake a stick at. |
275/70/16's don't even come close to rubbing either, and wont mess with your speedo as much.
Originally Posted by flyfishexpert
(Post 50603357)
265/75 will not rub
If you want to go with a larger tire you could always look at 255/85r16. |
265/75R16's rubbed slightly on my stock 01 w/ running boards.
As far as I know, you'll be okay with 265/75's on a '97. 00-on 4runners sat slightly lower, so may have more rubbing issues. Just to be safe though, check out the actual measurements of any tires you're looking at - they vary widely, even within a "size"
I have 285 BFG AT's, I started out with a 2.5" Daystar spacer lift and very little trimming. The very inside of the running board needed to be cut about a half inch, which was easily done with a razor knife. I now have the Tundra/OME lift and I've got good clearence. So you will need at least a 2.5" inch lift to make them clear any SERIOUS rubbing issues.
265-75-r16 for me only rub on my messed up valence. Everything else is fine.
i always figured that the 00-02 models sat up hire then the earlier 3rd gens.
Stock '97
I have two stock '97's with 265/75R16. No problems at all.
I dunno but 285 Interco SSR's sure as hell wont they measure out to 33.9" diameter.
Aaron |
(Post 50603520)
put your truck next to mine, youll think im SASed |
so if i get this tire/rim package i been looking at for awhile...
265/75R16 Radial MTZ, 16x8 Dick Cepek DC-1 $1276.99 and remove the running boards i should be good? http://www.desertrat.com/images_products/S_4662.jpg |
to OP: hey fellow pomona person!
the 285/75r16's will fit on your stock 6 spoke wheels, but they will rub the UCA's in front, thats why i had to buy new wheels with a different back spacing. i wish i had stuck with the 265/75r16. |
(Post 50603576)
dang, looks like ill just stick to 265/70/16 on my old factory rims...
