Why does my mileage still suck?
Old Aug 22, 2003 | 02:36 PM
Robinhood150's Avatar
Originally posted by Rayday81
I would try cleaning your MAF sensor real good and hope for the best.
He doesn't have a MAF, he has an AFM.
Old Aug 22, 2003 | 02:47 PM
Rayday81's Avatar
Oops, my bad:pat:
Old Aug 23, 2003 | 08:51 AM
szf2's Avatar
Originally posted by naksukow
buy an echo
I was thinking more along the lines of a 750cc (or greater) road bike. Hmmmm. Maybe I shouldn't work on improving my gas mileage. It will give me more leverage when bargaining witlh the wife for the motorcyle .
How are you calculating you MPG? Are you sure you are doing it right?
Fill up the tank, reset tripmeter, drive 100+ miles, fill up again, divide total miles traveled by total gallons needed to fill tank. . Also, I have calibrated my odometer/tripmeter on highway trips and its only off by a few miles (i.e. 98 miles really = 100). So, if I've gone 150 miles its really 153, but it doesn't make that much difference dividing 150miles/15 gallons or 153miles/15gallons, the mileage still sucks.
Anyway, thanks everyone for the suggestions. Looks like I'll figure out how to adjust the tps and double check the afm.
Old Aug 23, 2003 | 12:16 PM
Praufet's Avatar
You could try an electric fan and the ISR mod
Old Aug 23, 2003 | 03:07 PM
  #25
Paul H.'s Avatar
Try running a lower pressure like 35psi in your tires. By the way, I get better gas milage with my windows down than with ac on. 19mpg versus 16.5mpg.
Old Aug 24, 2003 | 05:34 AM
  #26
Victor's Avatar
Lower air pressure would create more rolling resistance which would likely reduce mileage. The 3.0 is so underpowered that having the A/C on forces you to practically floor it all the time which obviously isn't good for gas mileage. Interestingly, I only get about 1 MPG better mileage with the A/C off than on when on the highway. I think the A/C really hurts the city MPG more than highway.
I used to get 22 MPG with my 4.56 and 31's but now that I have taller tires I'm getting 19 or 20 on strictly highway driving. I think you need to look at your gearing a little more. I think the auto trans has a higher OD gear so the 4.88's give it close to what my stock gearing was before the tire upgrade. If you have plenty of power on the highway then perhaps taller tires would help.
Old Aug 24, 2003 | 08:42 PM
  #27
NCSU-4runner's Avatar
im running 33s with 4.56 gears, went to the mountains for the first time since my tire upgrade. . . man im glad i live in the flatlands, i spent more time in 3rd gear than 5th :pat:
primordialbeast117
Dec 19, 2015 12:23 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
dzldust
7
Oct 6, 2015 05:39 AM
mreagen
Oct 5, 2015 04:27 PM
EVars
Sep 29, 2015 02:06 PM
