why does?
Old Sep 11, 2004 | 04:27 PM
85TurboRunner's Avatar
why does?
why does my gauge i just hooked up get brighter and dimmer opposite of the instrument panel, i saw something once how to fix it i think but i dont remember where.
Old Sep 11, 2004 | 04:34 PM
Talking
figured it out.
Old Sep 11, 2004 | 05:20 PM
4-RUNNIN' FREAK's Avatar
I have the same prob with my boost gauge. I checked it 3 times and it still looks like it is connected right.
What did you do to fix?
Old Sep 11, 2004 | 05:30 PM
Gadget's Avatar
The dimmer is on the negative side of the wiring. So you must connect both the positive and negative leads of the light to both leads of the dimmer wiring. If you only connect one and the other to a normal ground you will have the problem you described.
Gadget
Old Sep 11, 2004 | 05:42 PM
actually i didnt really fix it, i just wired it into a light that comes on when i turn on the headlights so its always fully lit, and no you cant wire both leads into the ones on the dimmer switch, thats how i got this problem in the first place.
Old Sep 11, 2004 | 05:47 PM
I'll try something new next time I get time. I don't like how it reverses, but I still would like to be able to dim it. Maybe I'll try to get it on it's own dimmer so I can work the dash and gauge separate. Get a flat dial and drill it out so it fits behind the stock dimmer. Kind of like what some older auto radios have.
Think it's possible?
Old Sep 11, 2004 | 05:52 PM
Gadget's Avatar
Both wires must be connected to the dimmer. If it is not working correctly, then you have it connected to the wrong two wires on the dimmer.
The light must gets its power from the dimmer and then ground through the dimmer to work right.
Gadget
Old Sep 12, 2004 | 01:43 AM
since theres only 2 wires on the dimmer i dont think i had it hooked up wrong.
