Whiney clutch?
Old Apr 13, 2003 | 06:47 PM
ssbogger's Avatar
Whiney clutch?
The clutch in my 99 whines. I crank it up and its really loud but when i press the clutch pedal it quits. It makes a whirlling/whining sound. It gets less noticiable after ive been driving for about 15 min or so. What could this be?
Old Apr 13, 2003 | 08:11 PM
airrikk17's Avatar
check your clutch fluid make sure its up to proper level and then check for the clutch pedal free play and make sure its adjusted properly .
my 96 t-100 does the same thing , and after filling the clutch fluid to proper level it cut down on the squel, i checked the adjustment and its off a bit . by about half an inch , i jsut havent had time to adjust it , i suspect that after its adjusted it will stop squeling or be a lot less noticable.
some people have said this is bc of the pilot bearing set up that toyota uses , this im not sure of.
airrikk17
Old Apr 14, 2003 | 06:33 AM
rimpainter.com's Avatar
The whining you are describing is normal. Clutch fluid (which is brake fluid) wont do anything to the whine.
I went through the same worries when I first got my 5 speed.
Old Apr 14, 2003 | 11:24 AM
ssbogger's Avatar
so there is nothing that can be done for this? I read somewhere that there are two places that should be oiled/greased and this whine is the cause of one of the places not being oiled.
Old Apr 14, 2003 | 12:00 PM
Well, this will sound funny, but it depends on how bad the whine is.
Having gone from an Auto Tacoma to a 5speed Runner, I felt my whine was very significant. But, after a couple posts here and a couple trips to the dealer, I was reassured that this was normal.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
