Where is the tail light relay...?
Old Feb 5, 2007 | 10:38 AM
fornesto's Avatar
...on a '96 4Runner? My dash lights, tail lights, and "left your headlights on chime" are not working and, from what I've found on other threads, it should be my relay. I've checked the No. 8 10A fuse and it is bad. New fuses keep snapping as soon as they're installed. I think its a short somewhere or this relay.
1. Would a bad relay cause the continued blowing of fuses?
Other Information: I plugged in trailer lights the other night while the headlights were on. It sparked a bit.
Any other thoughts?
Old Feb 5, 2007 | 11:17 AM
eric-the-red's Avatar
On my 2001 it's in the fuse block under the hood. Check there.
Old Feb 5, 2007 | 12:03 PM
fornesto's Avatar
That's right. I found it right above the other fuses and labled and everything. Its strange that none of the literature calls it out as being there. The part should be in tomorrow. We'll see if that does the trick.
Old Feb 5, 2007 | 06:33 PM
FYI the fog light, defroster, EFI and power outlet relays are all the same as the tail light one. You can try switching in one of them before you buy a new one.
Sep 4, 2015 09:27 AM
Scotttekoch
Aug 31, 2015 06:09 AM
mreagen
Aug 18, 2015 06:37 AM
PopsDad1
Jul 30, 2015 02:21 PM
Johntom240
7
Jul 13, 2015 12:18 AM
