Where can I find these headlights?
Old Jan 20, 2004 | 12:06 PM
Jason B's Avatar
I like the extreme whites as well and have been running them for many years now.
Old Jan 20, 2004 | 12:08 PM
ldivinag's Avatar
Originally posted by OneTrickToy
Does anyone have a part number for the APC housings? I was looking online at CSK Auto but I can't search the headlights without putting in vehicle information. And my vehicle info only pulls up the sealed beams.
look at the bottom:
http://www.performancestyleattitude....headlights.htm
last 2 rectangular ones...
Old Jan 20, 2004 | 12:51 PM
Juggalo's Avatar
Originally posted by ldivinag
look at the bottom:
There's no listing for Toyota's there, are most of just a standard fit?
Old Jan 20, 2004 | 03:37 PM
OneTrickToy's Avatar
I'll have to see if any of my local CSK shops have them in stock... What about wiring? I can't remember if the sealed beams use the same connector. I guess I'll just pop the hood and see what I've got.
Old Jan 20, 2004 | 05:06 PM
  #25
Lethal's Avatar
yes it uses the factory connector. You just have to pull your grille and headlight bezels, unplug the old halogens.
Isert new bulbs into APC housings, drop the clip down, put on the rubber boot and plug it into the factory wiring plug. Put the bezels back on and replace the grille.
Voila all done and it's a lot brighter out at night now.
Old Jan 20, 2004 | 08:01 PM
  #26
Plays_with_Toys's Avatar
To make sure, do these fit the 89+ only or do they fit the older ones as well (I have an 87)?
Old Jan 20, 2004 | 08:07 PM
  #27
Jason B's Avatar
They will fit.
Old Jan 20, 2004 | 09:50 PM
  #28
Juggalo's Avatar
You guys have been a lot of help, I appreciate it
Old Jan 20, 2004 | 10:04 PM
  #29
Lethal's Avatar
they are a replacement for any vehicle that uses the halogen sealed beam headlights. They are a direct fit and plug into the factory harness. All you need is an H4 bulb.
Old Jan 21, 2004 | 02:59 PM
  #30
ldivinag's Avatar
the rectagular headlights that toyota used is the 6054 housing style.
and the bulb you use will have the 3 prong style...
Sep 4, 2015 09:27 AM
HookahRoo
Jul 20, 2015 07:06 PM
scottyg486
Jul 19, 2015 05:34 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
