When does gas light turn on in 3rd Gen?
Old May 6, 2005 | 03:50 PM
tgreathead's Avatar
Anybody know how much fuel is left in the tank when the gas light clicks on?
Old May 6, 2005 | 03:52 PM
Tacoma Dude's Avatar
In the Tacoma I know that it's about 2.5 - 3 gallons.
Why not just wait until you see it in yours, see how many gallons it takes to fill it up, and then subtract that # from the tank capacity in your manual?
ish's Avatar
ish
in my 00 4runner it comes on with 6 gallons left. something isn't right
Old May 6, 2005 | 04:27 PM
about 3-4 gallons are left in my tank when it comes on
Old May 6, 2005 | 06:01 PM
Mickdady's Avatar
There is a TSB for this. Can't seem to find it right now but I think it affects your year. Lemme guess. It drops off of full almost imediately after filling?
Old May 6, 2005 | 08:50 PM
tgreathead's Avatar
That is the plan, but until then I was just curious what other have experienced. I've only filled up once since buying the car and forgot to look then.
I just remembered that right after I drove away with the car the gas light went on and I filled up at the next station. The receipt says 14 gallons so the light clicked on with 4.5 to spare. That's a lot more than my Civic used to give me.
Old May 6, 2005 | 09:06 PM
nieuwendyk-25's Avatar
I have a 2000 4runner, and let me tell you it could run out at any time. The fuel guage has never worked properly...I have run out of gas twice. One of those times I rolled up to the pump!
Old May 6, 2005 | 09:28 PM
ish's Avatar
ish
yep, after like 20 miles its at 3/4 of a tank. its annoying. i just make sure i keep track of my mileage amd go by that. i usually fill up when my light comes on anyways just because its annoying having the light on
Old May 7, 2005 | 03:24 AM
X-AWDriver's Avatar
When it feels like it.
Old May 7, 2005 | 05:17 AM
waskillywabbit's Avatar
Drop a big ball bearing in your gas tank and when you can hear it rolling back and forth when braking you are about empty!
Old May 7, 2005 | 10:39 AM
Bigkahuna808's Avatar
MY light never goes on anymore. I used to stay on. The bulb burnt out, So I replaced it, and the light never worked ever again
Old May 7, 2005 | 11:59 AM
ROOFGOOF's Avatar
I have a 1999, when my light comes on I have put about 13.5 to 14.5 gal of gas in it... Doesnt the 3rd generation have 15 gal tanks ???
Old May 7, 2005 | 12:14 PM
I think it supposed to have an 18.5 gallon tank...however when I ran out it only took 16.5 gallons.
Old May 7, 2005 | 12:23 PM
ROOFGOOF's Avatar
Interesting... I usually get 17-18 mpg and I should probally know how big the tank is when the light comes on. I cant find my truck manual to see if it says how big the tank is???
Old May 7, 2005 | 01:01 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
!8.5 gallon tank on the '00. My light comes on solid with about 2.5 - 3 gallons left. There is a TSB on the '00 (plus other years? not sure) which will have the dealer replace the fuel sender and possibly the gauge, too.
Old May 7, 2005 | 02:00 PM
dragr1's Avatar
Mine does the same thing and with the gas light on, it never holds more than 14 gallons and usually clicks off at 12.5 to 13 gallons, I just squeeze another gallon in there. I tried a search but can't find anything about the TSB for this?
Old May 7, 2005 | 03:08 PM
89macrunner's Avatar
remeber air takes up space also and gas tanks arent perfect.....neither are yota gas gauges they seem to have always sucked on trucks\runners
Old May 7, 2005 | 03:28 PM
KZN185W's Avatar
The fuel tank on my 1996 Hilux Surf can hold 70 liters which is about 18.5 gallons. The low fuel warning light comes up when there's only 10 liters (2.65 gallons) left in the tank.
Air volume should be very minimal because the breather tube allows the air to move out.
Old May 7, 2005 | 06:06 PM
Rick F.'s Avatar
TSB EL010-00 for the '00 4Runner
http://pages.sbcglobal.net/larsdenne...Inaccurate.htm
Old May 9, 2005 | 05:09 AM
pfbmgd's Avatar
400km on the tank and it stays lit constant.
