wheel studs
front or back?
[list=1][*]Take a ball pien hammer and knock out the old one[*]Insert the new one[*]Put 2 or 3 thick zinc washers on[*]Thread on an old lug nut[*]Using an Air Impact Wrench, or a socket on a long breaker bar, torque the nut down to pull the stud into the hole[/list=1]
it is much easier with an impact wrench, just make sure you have somebody either stand on the breaks or put the tranny in 1st gear so the hub doesn't turn if it's the rear.
I thought you had to be careful of the hubs, so using a hammer wasn't a good idea. Long ago I cobbed together a vise of sorts and pressed it out. I think you can rent a similar kind of press - maybe at AutoZone?
You don't have to worry about anything with the hammer because it doesn't take much to knock them out, especially with a ball pien hammer. just don't use a mini sledge or anything because that would transfer alot of the impact to the hub, the ball pien is more of an instant impact that is absorbed mostly by the stud since the hammer is light. it took maybe to good whacks with my ball pien and they slipped out. I did, however, thread an old lug nut on about half way so I didn't marr the threads incase I found a use for the old studs,
Thats how the guy did it when I snaped one off putting my tires back on after installing my add-a-leaf.
I have a question about taking off the drum for the rear brakes on my 1st gen. I thought some one told me about pressing the brake or something to free it up so it will just pull it off. The kid at the tire place I took it to pounded all over it with a 3 pound sledge
. I cringed, but couldn't remember exactly what the trick was. I don't think he hit it hard enough to damage it, but I'm right.... right? It just seems to me pounding on something that needs to stay round is not a good idea.
Anyone have the answer?
. I cringed, but couldn't remember exactly what the trick was. I don't think he hit it hard enough to damage it, but I'm right.... right? It just seems to me pounding on something that needs to stay round is not a good idea. Anyone have the answer?
Originally posted by keisur
there are two threaded holes near the center hole on the drums. I believe they are M10x1.25 or maybe M10x1.5 You can go to the store and get two of each bolts so you have them and then you screw them in if the drum is stuck and they will basically press your drum off. You could also open the adjuster access slot in the backing plate and back the adjuster off to loosen the shoe's grip.
Oh ya, just to be sure, make sure you don't have your parking brake on!!!
parking break!
thanks for that last tip, I was trying to get the drum off with the park brake on, (failed). Took the parking brake off and the drum came off easily.Thanks for your help homies, word!
Who has replacement hardened wheel studs?
Or who has the best price for wheel studs in general?
At the dealer's here they want over $9.00 each what a ripoff!
The best price I've found so far is for a set of 6 for $21.71, but for a Land Crusier....
If not, when I get a chance I'll see if I can get ARP to make them.
Seems like they don't have wheel studs, I'll get the factory part # and try again..
What I'd really like are hardened studs.....
Front: {Dealership Price}
90942-02049 $2.92 {$2.16 @ 1st Toyota}
Rear: {Dealership price}
90942-02052 (96-00) $4.77 {$3.54 @ 1st Toyota}
90942-02079 (01-02) $4.37 {$3.25 @ 1st Toyota}
kgcwb44
Jan 29, 2023 10:02 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
