wheel spacers
Old Mar 10, 2005 | 12:36 PM
hiloracerboy84's Avatar
wheel spacers
whats the widest wheel spacers that are okay to use with stock lug nuts? ive heard of people using spacers over an inch thick...do you have to change your lugs or something or would they be okay with stock ones
Old Mar 10, 2005 | 12:45 PM
Bigkahuna808's Avatar
Eh, go with adpaters over spacers. All pro-off road.com sells them. Spacers sometimes give you a front shimmy.
Old Mar 10, 2005 | 01:08 PM
how do those work? you bolt the spacer up to your stock lugs, and bolt your wheels to the new lugs on the spacer?
Old Mar 10, 2005 | 01:28 PM
4Crawler's Avatar
Spacers attach to the existing lug studs (up to 1/4" usually works for stock, longer studs needed for up to 3/4") and then adapters are available from about 1" on up. An adapter differs from a spacer in that is has 6 studs pressed into it that the wheel bolts to and 6 holes that bolt the spacer to the hub. So you end up with 12 lug nuts instead of 6 per wheel.
Here is a 1/4" spacer:
Here is a 1.5" wheel adapter:
Old Sep 11, 2005 | 11:27 AM
Stegall984R's Avatar
From: OmG, Hi2U !!! .... DANG, my chic's got some SEXY eyes.... among other things. WOOT WOOT !!
i just stacked like 15 washers on mine and slaped the wheels back on.. Its mad tyte dood.
Old Sep 11, 2005 | 01:36 PM
PistonSlap's Avatar
I don't know if 'mad' is the best word to describe that.
Old Sep 11, 2005 | 02:41 PM
Flamedx4's Avatar
Apparently the emoticon for tongue-in-cheek is invisible...
punks_is_4x4
Aug 21, 2015 01:35 PM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
Yotoder865
Jul 9, 2015 07:51 PM
