What's the right name for this?
Old Jul 21, 2005 | 02:34 AM
Beartracker's Avatar
When you open the drivers door on my 01 Tacoma extended cab and look down at the bottom edge there is a plastic strip that is about 3" wide and runs from the front of the bottom door frame to the back and holds the carpet down. It has about four screws in it. The screws no longer hold it down right and every time I get out I knock this thing loose.The plastic extenders that the screws go into are broke and they just wont hold it tight.
Anyone know what the proper name is for this plastic carpet holder ?
Also if anyone knows where I can buy one please let me know. Thanks, Mike
Old Jul 21, 2005 | 02:41 AM
jc1kz's Avatar
it is the "door sill" here is an example of what it looks like and what it is called.....
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7987374881
Old Jul 21, 2005 | 03:44 AM
Yep, That's it. Thank you. Now I need to find one. Ebay motors doesn't have them. Mike
Old Jul 21, 2005 | 03:50 AM
jc1kz's Avatar
what's your interior color? i'll look for one here for you......
Old Jul 21, 2005 | 03:52 AM
toyguy1986's Avatar
Called a door sill scuff plate, find In junk yard, Toyota
Old Jul 21, 2005 | 05:15 AM
Looked all around the parts dealers and the one's that sell the body parts but never found this part. My truck is Luner Mist and the interior is Grey. Thaks for your help. Mike
Toyguy, We have one junkyard in my town and it has "one" Tacoma in it but it's not a match or even close. This is a true Tacoma town as that's all you will see back in these mountains. Not many will make it to the junk yard as long as they can make them run and haul around there coon hound's and Bear dog's. Mike
Old Jul 21, 2005 | 08:28 AM
Bob_98SR5's Avatar
beartracker,
im going to save you A LOT of money, time and frustration:
don't buy a new door sill plate. run down to your local hardware store and buy these little inserts. you'll have to find one with a male end that fits.
cut off the ends of the door sill plates that protrude downwards. insert those little plugs into the existing holes in the body and then screw down the door sill itself.
bob
Attached Thumbnails What's the right name for this?-insert1.jpg   What's the right name for this?-insert2.jpg
Old Jul 21, 2005 | 09:34 AM
Bob, Thank you! I spent 20 years in the construction trade and never even thought of that.I have a bunch of different wall anchors in my work shop, Problem solved guy's! Thanks again, Mike
