What in the world is this???
Old May 27, 2004 | 10:32 AM
swooopeno's Avatar
04 runner, rear compartment, behind wrench.
I found this clear tube that was just hanging there, not connected to anything. THen I took the wrench out, and there was this black female connection. So I plugged it in. Talked to some other people, they say their tube is not plugged in either. ANyone know what this is, or if it should be plugged into the black tube????
Old May 27, 2004 | 10:34 AM
BajaRunner's Avatar
Looks like the rear window washer fluid tube, but, I could be wrong.
Old May 27, 2004 | 10:37 AM
Good Times's Avatar
rear window washer
Old May 27, 2004 | 10:44 AM
SLC Punk's Avatar
Either a rear washer hose or some sort of a drain hose.
Old May 27, 2004 | 11:51 AM
Mad Chemist's Avatar
That's where you put your Amsoil synthetic blinker fluid, nets you like 8 hp!
Old May 27, 2004 | 12:04 PM
4Sport's Avatar
LOL - Good one chemist.
Swoopeno, If that thing wasn't connected, your washer fluid might have been leaking all over the place (in that compartment). Ever use your rear washer fluid? - Mine was plugged in. Strange yours was not.
Old May 27, 2004 | 01:02 PM
r0cky's Avatar
eeks, this makes me want to go out and check mine ... hope all is well and that nothing spilled in your rear compartment ... thank you for posting this to remind us to check it out!!
Old May 27, 2004 | 01:03 PM
4RUNR's Avatar
Guest
That is certainly not washer. On the 3rd gen the tube runs along the driver side cargo window and just hangs into the air vent behind the bumper. It probably comes off the sunroof.
Old May 28, 2004 | 06:31 PM
TechWrench's Avatar
Just checked mine. I doubt it is for the rear washer. The tube is too large in diameter, and the black female fitting it goes into is too loose a fit to be able to provide any lift to fluid. It looks more like some type of vent or drain. Can't find any reference to it in the manual, so far.
Old May 29, 2004 | 03:26 AM
X-AWDriver's Avatar
My guess it's a drain tube also to drain water from an area where it's prone to collect;most hatchback cars have them on the sides under the hatch.
Old May 29, 2004 | 05:06 AM
Parsh's Avatar
Mine was connected and had some water spots on the inside. Where it goes, I can't tell though...
Big Little Bear
230
Nov 13, 2023 11:42 AM
rubrsidedwn
Jul 7, 2016 07:28 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Toys4parts
Sep 26, 2015 01:56 PM
tysen86
Sep 25, 2015 11:15 PM
