What wire did I cut?
When I was replacing oil filter on my 02 Runner I accidentally cut a wire. If you look through the wheel well, the wire sits just below the oil filter. There is a connector for this wire that plugs into a bracket welded to the frame just to the left and below the oil filter. There a 2 wires going into the connector, one white and one black.
I reconnected both wires, but I wan't able to seal them with stock rubber plugs as well as they were sealed originally.
Does anyone know what those wires control? I traced them and they go into a fat harness that's routed at the top/front of the radiator, so I really can't tell what they do.
Thanks!
Thanks!
I never traced where it comes out of. I spent much to much time playing with the truck on Friday. I was just happy to fix the wire and call it a day
I was just hoping that someone would know without having to trace it. Maybe someone with a wiring diagram?
You really can't miss that wire if you ever pull the wheel well flap on driver's side.
sandyota
Feb 4, 2021 11:16 AM
v_man
Jul 23, 2015 04:01 PM
Johntom240
7
Jul 13, 2015 12:18 AM
crashburnoveride
Jul 10, 2015 06:39 AM
