View Poll Results: Which screen resolution do you use the most?
Less than 800 x 600 pixels
0%
800 x 640 pixels
9.74%
1024 x 768 pixels
45.45%
Greater than 1024 x 768 pixels
44.81%
Voters: 154. You may not vote on this poll
What screen size resolution are you using?
Old Feb 16, 2004 | 09:57 AM
Bob_98SR5's Avatar
Guys,
Let me emphasize: PLEASE VOTE IN THE POLL! just replying in the thread will make the analysis a pain.
This is a poll question that may have affect on the layout and other goodies we have planned for Yotatech in the near future.
"What screen size resolution are you currently using?"
If you don't know, follow these steps:
>> Start >> Control Panel >> Display >> click the "Settings" tab
You will see in the bottom left hand corner what your current resolution is set at.
Mac users = i have no clue but you guys are pretty bright and don't need any instructions on how to figure this out, right?
Also, if you use more than 1 computer at home, work, etc, please answer with the computer resolution you use the most.
This post is only going for 5 days until Friday, February 20, 2004.
Thanks,
Bob
Old Feb 16, 2004 | 09:59 AM
Dr. Zhivago's Avatar
Away
1024x768x85Hz
19" Monitor
G
Old Feb 16, 2004 | 10:00 AM
Waterboy's Avatar
800x600 home and work.
Old Feb 16, 2004 | 10:01 AM
jacksonpt's Avatar
Senior Member
2560x1024
Old Feb 16, 2004 | 10:06 AM
PoBoy's Avatar
1280 X 1024 is what I run.
I recently started programming for 1024 X 768 and larger resolutions. It's becoming the standard minimum res.
Old Feb 16, 2004 | 10:12 AM
waskillywabbit's Avatar
Resolution
Desktop at work - minimum 1152 x 864 always for drawing applications
Laptop - always 1600 x 1200, unless using with an LCD projector which uses lower resolution
MTL_4runner's Avatar
1024 x 768 @85hz
Old Feb 16, 2004 | 10:23 AM
SteveO's Avatar
laptop 1600x1200,
laptop plugged into a 20" flatscreen set to 1600x1200
Old Feb 16, 2004 | 10:24 AM
va97runner's Avatar
1280x1024 for me, but when the g/f gets on she changes it to 800x600!! :wtf:
By the way, you might want to edit the poll options... I'm assuming you mean 800x600 not 800x640?
Old Feb 16, 2004 | 10:42 AM
Bob_98SR5's Avatar
VA,
Yes, you're right. it is 800 x 600. but i think people seem to understand.
bob
Old Feb 16, 2004 | 10:47 AM
hungryStu's Avatar
Resolution: 1024 x 768 @ 90 Hz
Depth: 32-bit Color
Old Feb 16, 2004 | 11:36 AM
Mike06's Avatar
Depth: 32-bit Color
Same here.
Old Feb 16, 2004 | 11:47 AM
OneTrickToy's Avatar
1024x768, 32bit color depth, @ 60Hz.... I'm stuck. I've got a laptop.
But the new comp I'll be building will be set WAY higher. I'll have the ability to double that resolution I'm building a powerhouse with an ATI All-In-Wonder 9800 Pro.
Old Feb 16, 2004 | 12:48 PM
midiwall's Avatar
1280x1024x32 at home and work. I'd run 1600 at work but I transfer screen based stuff back and forth to home and I'd get messed up on the home side.
Old Feb 16, 2004 | 12:55 PM
tour4fun's Avatar
17" 1280x1024
Old Feb 16, 2004 | 02:06 PM
turboale's Avatar
Widescreen... 1152x768
Old Feb 16, 2004 | 02:08 PM
Krash's Avatar
I run the same res at home.
Old Feb 16, 2004 | 03:00 PM
PoBoy's Avatar
Hey Bob...just an FYI, the poll was there when I first posted. Was something amiss?
Old Feb 16, 2004 | 04:28 PM
Fink's Avatar
Now I'm running a dual monitor setup and I have both set to 2560x1024.
Fink
Old Feb 16, 2004 | 07:16 PM
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
1280x800: Laptop LCD
1280x1040: Desktop 17" LCD
