What is the purpose of this?
Old Aug 24, 2012 | 01:12 PM
sampsonite987's Avatar
Hello everyone, first time poster.
'97 4Runner 4X4 SR5
Ignoring the fact that this is one of the worst DIY attempts I have ever seen, what would be the reason for this? There are what appears to 2" coil spring spacers installed, so my first thought was they were attempting to extend the end links because of the lift (not that they are of any use in this state though). Any other reason this may have been done?
Old Aug 24, 2012 | 01:27 PM
motocrossaddict223's Avatar
If thats your sway bar, it could be a disconnect for it to allow for more articulation. That being said, i dont know what part thats on so i could be wrong. Is it on both sides?
Old Aug 24, 2012 | 01:46 PM
It is the sway bar. Same on both sides. If it was a disconnect, why have it extended 2.5 inches above the factory end link? Seems to me the sway bar is basically pointless after that "mod".
Old Aug 24, 2012 | 02:12 PM
I dont know, wish i could tell you but i didnt do it. Maybe its supposed to slide down 2.5 iinches or something
Old Aug 24, 2012 | 02:25 PM
Blown96's Avatar
Well I thought I was the only person that was that home grown on here. Tire bushings are a classic. That being said will it in screw up top? It looks like the thread has been welded below the sway bar
Old Aug 24, 2012 | 02:29 PM
cubuff4runner's Avatar
It looks like when they lifted it they thought that the swaybar links needed to be extended. The swaybar will still work, but the lack of bushings and theall-thread link is probably going to snap sometime. I would get a set of disconnects.
Old Aug 24, 2012 | 03:32 PM
SCToy's Avatar
Maybe to compensate for a bracket lift? Looks like those 'extensions' would snap of quite easily though.
Old Aug 24, 2012 | 04:08 PM
James Woods's Avatar
Wow, now that is some jimmy rigging. I don't why they went through all the trouble, I just removed my sway bar when my end links went bad on my 3rd gen, hardly even know its missing.
By the way your inner axle boot is leaking.
Old Aug 24, 2012 | 04:35 PM
stockwell45's Avatar
Jeez, that almost scares me as to what else could be "tweakerfied" on your 4runner. I'd check everything in the engine compartment and do a full sweep of everything on the undercarriage after seeing that.
Old Aug 24, 2012 | 05:57 PM
Stu Pidasso's Avatar
Would that be proprietary?
Old Aug 27, 2012 | 05:32 AM
Haha, some good responses guys. I have seen my fair share of redneck engineering, but generally those fixes at least somewhat accomplished the desired result. This not only looks terrible, but would be worthless if I really needed the sway bar. Granted, if I were in a situation where I really needed it, some other awesome engineering marvel that I haven't found yet would probably give out and send me rolling into a ditch.
Old Aug 27, 2012 | 05:41 AM
waskillywabbit's Avatar
Commonly known as booty fab.
Remove and replace.
I sell endlinks and discos for lifted 3rd gens so you can do what they attempted to do correctly.
:wabbit2:
justdifferentials
14
Jun 11, 2017 08:36 PM
Badfish740
Diesel Swaps
Dec 9, 2016 06:18 AM
A2theK
Sep 30, 2016 12:50 PM
Toys4parts
Sep 26, 2015 01:56 PM
dammitcam
Sep 10, 2015 02:37 PM
