What is the harness for?
Old Jan 20, 2014 | 06:03 PM
MB4runner's Avatar
Hey guys... was looking at my MAF to see how difficult it is to access it and clean it when I saw this harness dangling beside the intake tube. Obviously it's supposed to be connected or secured somewhere but what is it for or what does it do? It's on a 99 3.4L 4runner.
Old Jan 21, 2014 | 01:01 AM
reaj's Avatar
I have one too!
Old Jan 21, 2014 | 11:19 AM
scottw's Avatar
Noise Filter?
Looks like the EC Noise Filter. Does it have two wires, "Brown" and "Black w/Red Stripe" coming to it? If so, that is the noise filter. It shouldn't have any exposed pins -- it should look like black epoxy in the exposed end. If you see exposed pins, then someone has removed the filter block from the connector.
It's normally just taped or wire-tied to a nearby wire bundle to keep it from flopping around.
Edit: I believe the Toyota part number is 90980-04083. Alternately called a condenser or noise filter.
Old Jan 21, 2014 | 02:49 PM
MB4runner's Avatar
Yup it does look like black epoxy. So thats good nothing is wrong then. And I just noticed thats your first post? That's awesome, thanks for signing in to help out!
Old Jan 21, 2014 | 06:11 PM
scuba's Avatar
The 95-97's had a 3 wire MAF and a separate 2 wire air temp sensor. After that they changed to an integrated temp sensor with the mag and changed to a 5 wire.
I'm 99% sure that's what you're seeing there.
Not sure why they didn't remove that part of the harness.
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
tshort48
Sep 27, 2015 01:04 PM
Toys4parts
Sep 26, 2015 01:56 PM
Hugh_Mann
Sep 16, 2015 03:59 AM
