What do ya carry?!?!
Hey, I was just wondering what everyone carries in their 4Runners that can be used in a time of an emergency.
My schtuff:
This is my list and all that I have for an emergency. What does everyone else have? :fireman:
My schtuff:
- Frist Aid Kit-basic bandages, burn cream, needles, pins, latex gloves, so for and so on
- Jumper Cables-basic ones, although they will probably never be used, but you never know
- Bungees-Rummer EPDM style, strong with metal hooks
- Mag-Lite-3D cell red light mounted for easy access
- Latern Style Flashlight-Ray-O-Vac light that converts to a latern style light
- Tool Kit-Kit includes pliers, ratchet set, screw driver set, allen set, jewlers screwdrivers, etc.
- Mini Strobe Light-a cool gadget that I picked up at the firehouse. It is run by 1-C sell battery and flashes every 2 seconds. Very very bright. We use them on life vests for water rescue. This is good for attracting attention or alerting of danger
- Fire Scanner-my channels are programmed in along with weather advisories channels
- Cell Phone-Nokia 3390 phone with excellent range
- Blue Fire Light-very very bright light used to go on fire calls. I can use it in a emergency to attract attention. 60,000 candle power
- Vehicle Supplied Tool Kit-for changing spare and so on
AMA or AAA.
Seriously though, pretty much the same as you.
-First aid kit
-Air pump
-Reflective triangles and spare tire change equipment
-Tow strap
-CB Radio
-Cell phone
-2 Maglites, spare batteries
-Chocolate and other energy food
-Blankets
-Assortment of tools, wrenches, pocket knives, duct tape, etc.
-Spare drivebelts, oil, tranny fluid, coolant, etc.
-Compass, binoculars, maps
-First aid kit
-Air pump
-Tow strap
-CB Radio
-Cell phone
-Blankets
Co-Founder/Administrator
This will be fun
I'm a picoholic, so I'll provide links to pics too
Starting from the front and working back:
I don't carry any extra oil in the rig as it has never burned a drop between changes.
- Fire extinguisher mounted on drivers floor mat
- Maglite mounted on passenger floor mat
- CB radio for off road communications and emergencies on road
- GPS unit in case I get lost while in the mountains
- Cargo box filled with the following:
Complete screw driver set, hammer, head lamp, electrical tape, various electrical connectors to fix broken wires, more electrical stuff including huge range of sizes of zip ties, GI shovel, bungee cords, several sets of mechanics gloves, wrenches, sockets, pliers, spare interior bulbs, spare H4 55/60 watt stock bulbs, special long wrench for wheel lugs, 12v compressor, Craftsman heavy duty 1/2" drive impact wrench, complete metric impact wrench sockets, tires gauges, tire inflation/deflation gauge from Griot's, lots more in the cargo box too. Whewwwwwwwww
- Power Tank for airing up tires after trail rides and for an emergency flat repair, or to power the impact wrench
- Two blankets for if I have to grovel in the mud or dirt for a repair, or for laying down in the interior for transporting items
- Left rear side pocket carries butt wipe, first aid kit, tire repair plugs, 30' snatch strap, soap in bottle for after using roll of butt wipe
- Right rear side pocket full size binoculars
- Another fire extinguisher mounted at the far back right
I never thought of a compass and that. I will have to add that sometime. I will have to get a tub like you Corey and put some stuff in. I do have a shovel, but I only put that in when it snows just in case. I will have to add some more stuff seeing what everyone else has! Cool, thanks guys! :fireman:
Here are a few items that I carry around with me
-12v Air Compressor
- Wide Array of tools
- various snack bars
- jug of water
- Maglite
- Cell Phone
- Tow Straps
- Glock 40
I need to add a few more items to the kit!
-12v Air Compressor
- jug of water
- Maglite
- Cell Phone
- Tow Straps
- Glock 40
I carry a lot to stuff that never gets used, or not yet anyway.
In winter only:
sleeping bag
tire chains
Year round:
full 5 gallon gas can
ABC fire extinguisher
jumper cables,
--all stored in a milk crate at the center of the tailgate for easy access
3 ton floor jack
2 ton OEM bottle jack w/ extension
2 ton jackstands (1 pair)
4 wooden 1x6x18 boards for jacking in sand or snow.
metric 'star' lug wrench, spray paint marking the size my lugs are.
Aluminum alloy Voile skiing shovel (doubles as cheater bar for those really stuck or tight bolts.)
winch accessory kit(tree strap, pulley, shackles, gloves)
11,000 pound nylon ratchet tie down, 30 feet long
20 foot nylon snatch strap
assorted tools from 2 small tool kits, 12 extra sockets up to 26mm, extra screwdrivers, spark plug socket, extensions, leathermans tool, electrical tape, and the ultimate tool... DUCK TAPE.
Clear and black RTV sealant, white grease, red and blue loctite
1 gal of motor oil
1 gal of gear oil and pump
1 gal of undiluded anti-freze
2 gal of purified (distilled) water
long sleve sweat shirt, old jeans, 2 coleman rain ponchos.
Bic cigarette lighter or 2
-- all in 6 milk crates in the bed foreward of wheels
several twin AA flashlights
crappy handheld CB radio
-- in the cab
In winter only:
sleeping bag
tire chains
Year round:
jumper cables,
3 ton floor jack
1 gal of motor oil
-- in the cab
Here is something that saved us last year when a rig broke below rocky saddle, welding rod and some modified jumper cables. With 4 batteries you can really get some good welds.
But one thing I am seeing that you guys are missing, parts to repair commonly broken items, like CV's, or U-joints, pieces of runner and plug kits for tires..
I run custom front shafts in my RC44, and the u-joints are welded in, so that increases the chances of busting a U-joint only and not damaging the yoke, so i carry an air grinder and replacement U-joint, plus joints for my drivelines.
Tire repair kits can be had cheap if you know where to go.
I picked up a nice one from Wal-Mart last year or so for around $12.
I have seen them elsewhere as high as $40, and the contents are the same as this Victor one from Wal-Mart.
http://www.pnw4runners.net/temp/tirekit1.jpg
http://www.pnw4runners.net/temp/tirekit2.jpg
It comes with 20 tire plugs, and also about 5 or so big round patches. Also cement, roughener scrub thingymabobber, and the two handles with a reamer to ream out and roughen up the hole, and the tool for inserting the plug.
This is actually a spare kit in the photos here I picked up a short time back.
Going to give it to my youngest when he gets his license here soon.
In fact I'm putting together an emergency kit/toolbox combo for him to keep in whatever he ends up driving.
I did this for my oldest some last year too. He's got the same kit, and a 12v pump for the tires, and plenty of tools I put together for him to have on hand.
Corey
Corey
I picked up my new emergency air compressor. I'll try it out next time I need air in the tires.
260 psi, 12-volt power, pressure gauge, emergency light & on/off switch. Nice and compact. Nothing special, but it should do the trick:
http://www.canadiantire.ca/assortmen...=1027974151175
Here is what I carry:
Jumper Cables-Heavy Duty
Bungees-metal hooks
Mag-Lite-3D cell Blue light mounted for easy access
Screw driver set
Cell Phone-Nokia 8260 phone with excellent range
Tie Downs
Roll of Paper Towels
Tow Strap
Bungees-metal hooks
Screw driver set
Tie Downs
Tow Strap
Knives are also a good thing to carry with you. I forgot to mention that I carry one of those on my rig too. Very useful and handy in some situations. I will have to seriously consider some items you guys have to add to mine. Some really good ideas here! Thanks! :fireman:
I can't believe yall carry so much, this is what I carry:
cell phone
small mag light,need to upsize it though
nylon snatch strap
small air compressor
a few tools
duct tape
a plastic sheet, in case a window is broken
and lots of good luck
I like alot of everybodies suggestions, might add some soon.
cell phone
nylon snatch strap
a few tools
duct tape
Originally posted by NerfHerder-97SR5-
I've got about 2.15 - 4.45 in change depending on what day during the week. I keep it in a custom location known only as the "ash tray".
That, and frickin sharks with laser beams.
Unfortunately an AAA card is only good for the highway.
Take a look at these pics & vids Shane shot Saturday where him & Crash went too.
http://4-low.com/pics/7.27.2002/
That's why it's a good idea to be stocked up on stuff in the wilderness.
The vids are awesome.
Corey
Corey
