What to do? Blown HG and more, 95 V6
Old Dec 27, 2004 | 11:16 AM
jbaehr's Avatar
I have a 95 4Runner, V6, 140k, with the typical white smoke, bad idle, etc, of a blown HG (10 - 15 miles on it like this). Since, I've had trouble starting plus a new "clanking" noise.
A mechanic confirmed blown HG quoting $2000 + parts but feared lower end damage due to the noise (which is now consistant at startup) and basically called the engine a gonner, recommending a JDM replacement or rebuilt quoting $3000 installation + parts.
I'm leaning towards a JDM replacement, which I figure I can install myself rather than tearing the old engine down to find what may be more expensive stuff to repair.
First, is this rational thinking? Second, I'm a design/build contractor but haven't turned wrenches on a truck since rebuilding a 73 CJ5 back in High School. How hard is the install?
I think my mechanic is not really interested in helping out with this, would also be interested in mechanic recommendations, East Bay, NorCal.
Thanks,
Jim
Old Dec 27, 2004 | 12:01 PM
PAhydrohead's Avatar
I assume you checked the Vin # on your truck and have determined that the head gasket can not be replaced under warranty, right? If not, better check b/c you might be in for a nice x-mas gift! If you haven't searched the archives about head gasket recall do so. Good luck.
Old Dec 27, 2004 | 02:32 PM
MTL_4runner's Avatar
Most of the service campaigns are ending for the HG....you still need to check with Toyota corporate (just give them the VIN).
I would do the JDM if you can or at least a complete running motor as a swap.
You have no idea what you will encounter as you do the teardown and not worth the headache in my book.
Old Dec 27, 2004 | 03:23 PM
Bigblock's Avatar
toyata only fixes them one time.i know ,used to work there.i have a short block and i"ll put it in for you.i"ve done hundreds.40k on short block.e mail me.gaskets dont bother me ,clank does.
Old Dec 28, 2004 | 09:29 AM
jbaehr's Avatar
My VIN# is just out of the campaign range, which ended 11/30/04.
Jim
4banginRunner
Nov 13, 2015 05:23 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
smilen724
13
Nov 8, 2015 04:11 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Toys4parts
Sep 26, 2015 01:56 PM
