What can I use as rear recovery points?
Old Mar 26, 2003 | 11:40 AM
codlord's Avatar
Question What can I use as rear recovery points?
I have a second generation 1990 Surf (Jap 4Runner). On the front it has a fairly tough looking hook which I can use as a recovery point, but nothing at the rear except for what look like two tie-down points underneath either side of the underslung spare wheel (you can just see one at the bottom-right of the attached pic). Can these be used as recovery points or is that a bad idea?
If not, are there any recommended alternatives or ideas for where to weld a custom recovery point?
Thanks
Old Mar 26, 2003 | 12:10 PM
delboy's Avatar
Yeah! you can definitely use those holes for towing out of a tight spot. I used them several times on site when i got stuck in 30 tonne dumper truck tracks and had to get a dozer to pull me out. If it takes that, it'll take anything!
Delboy
Old Mar 26, 2003 | 01:39 PM
slowyota's Avatar
Have a class III recieve hitch intsalled and use that. They're tougher than hell and can also be used to tow. And in the long run will probably save you money rather than having tow hooks welded on.
Old Mar 26, 2003 | 01:51 PM
Yah that looks like one of those D-holes used when transporting vehicles....
Tugging/Towing Basics
or if you have a hitch...
Shackle bracket
Old Mar 26, 2003 | 02:12 PM
jx94148's Avatar
I use a D ring shackle through one of the holes in the frame near the rear bumper.
Old Mar 26, 2003 | 03:38 PM
HBoss's Avatar
Me too. I've got one on each side in the rear and a spare shackle in the Runner in case mine breaks or someone else needs one temporarily. Not exactly the same for a 2nd gen. but very close.
Flying91
45
Apr 11, 2024 04:39 PM
pyramid
Jul 30, 2015 10:05 AM
keithporter83
Jul 18, 2015 12:37 PM
icentropy
Jul 14, 2015 10:23 AM
jakebarrett
Jul 10, 2015 07:15 PM
