Water pump and timing belt
Old May 14, 2003 | 08:47 AM
b_melli's Avatar
Hi All,
Just curious if the same thing ever happened to any of you:
I had the timing belt and water pump replaced about 20k ago on my 92 4runner. The new belt
got distroyed within 20k because a pin
worked itself loose from the water pump and started chewing on the belt.
I'm just curious if that could be attributed to poor installation, or part failure.
thanks,
bruno.
Old May 14, 2003 | 10:26 AM
lunatic14r's Avatar
never seen it happen but i hope the fix it for free. the only pin i recall would be the one for the tensioner.
Old May 14, 2003 | 10:32 AM
rimpainter.com's Avatar
Where did you have it done? Part of installing the water pump and timing belt should be a quick inpection of the surrounding parts. I would get the shops take on things.
Old May 14, 2003 | 10:41 AM
b_melli's Avatar
Unfortunately my truck failed while I was up in the mountain, 2 hours from home.
I had a friend help me tow it to a local mechanic. The mechanic was very careful not to point fingers and pretty much told me that I'd be out of luck trying to get the original shop to foot the bill if they didn't want to.
So at this point I'm just curious. Luckily
the belt failed in a way that didn't cause
head damage.
bruno.
Old May 14, 2003 | 10:46 AM
head damage.
bruno.
Timing belts are go/no go items. (Well, they can skip teeth)
You engine is non-intrusive, which is what saved you. Otherwise you would have a pandora's box filled with valve train parts right now.
Hope everything works out for you.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
