VSC / TRAC defeating - is anyone closer?
Old Aug 25, 2005 | 04:45 PM
  #441
GSGALLANT's Avatar
Yeah... you might be right. Hmmmm... I wonder if I can find a momentary pushbutton that has normally closed contacts, and when you push the button, the circuit gets broken...
Old Aug 25, 2005 | 06:43 PM
  #442
aowRS's Avatar
Take a look through the drawers at Radio Shack. It might end up being a push-button switch that you hide under the dash or elsewhere, unless you are not concerned about how the end result looks.
That's the reason I went with a stock fog light switch and made my own label.
Andreas
Old Aug 26, 2005 | 07:30 AM
  #443
emptypockets's Avatar
I got all the parts and pieces and will be installing the AndyMod this weekend hopefully. Anyone have problems with installation when you have a car alarm? Mine's a Viper. Can't imagine any problems but wanted to double check. I can't wait to smoke my Coopers!
Old Aug 26, 2005 | 07:38 AM
  #444
aowRS's Avatar
The mod only requires that you cut the ground wire leading to the brake fluid pressure sensor. I see no reason why this would affect anything else on the truck. Let me know if you have any questions.
The feeling of complete freedom when I smoked my REVOs 30 feet down the street was great. Then I realized how much they cost and switched the systems back on!
Andreas
Old Aug 26, 2005 | 07:54 AM
  #445
You da man Andreas! I'll give it a go this weekend if I can find the time and let you know how things go!
Old Aug 27, 2005 | 07:23 AM
  #446
PRESTO! AndyMod is installed and working properly! The hardest part was fishing the wires through the grommet...very simple and easy installation. My only problem was finding a switch. I went to Radio Shack and bought a simple rocker and tried to glue it to the dash panel near the fuse area. It didn't stick! That's my only dilemma...otherwise, this is a slick mod!
BTW...my Coopers really smoke when they spin!!! LMAO!
Old Aug 27, 2005 | 08:13 AM
  #447
aowRS's Avatar
Sweet! Now go take a pic of the rubber patch!
How did you attach the wires - a simple crimp?
Andreas
Old Aug 27, 2005 | 08:39 AM
  #448
I used crimp connectors on the switch inside. In the engine compartment, I just used twist on connectors. Electrical taped everything together really well and voila! I think I found a solution for the switch thing, because glue will not hold long term. Near the fuse panel, there's a larger knock out piece. I'm going to drill a hold into that and the switch will pop right in and stay for good! I'll post burnout pics sometime next week (when the wife's not around)!
Old Aug 30, 2005 | 01:44 PM
  #449
Finished Project
Here it is...the completed switch on the Andymod! It works great! Thanks Andreas!
Attached Thumbnails VSC / TRAC defeating - is anyone closer?-imag0081.jpg
Old Aug 30, 2005 | 02:27 PM
  #450
yabedude's Avatar
I so much want to do this mod, but am fearful of taping into the wrong wire lead. I'm wondering if any 4th gen owners have done this yet and have't posted their results?
Old Aug 30, 2005 | 04:20 PM
  #451
aowRS's Avatar
emptypockets,
The switch looks like a clean installation - good job! Now go behind the nearest WalMart and lay some rubber!
Andreas
Old Aug 30, 2005 | 04:56 PM
  #452
94x4's Avatar
Guest
I was going to suggest simply locating the the "VSC/TRAC" wiring harness and placing a switch in line with the circuit(s) so that you could then manually switch it on and off, but you seem to have finally figured it out.
Old Oct 16, 2005 | 10:11 AM
  #453
Spensane's Avatar
Can someone post a pic of the wirs they tapped in to do the AndyMod on a 4th gen v6 4Runner. I have read through this thread and could not find anything exact. I need to lay some rubber.
Old Nov 14, 2005 | 07:21 PM
  #454
Citykid's Avatar
Any pictures of the connection at the red wire that is to be cut?
Old Nov 14, 2005 | 08:20 PM
  #455
calrockx's Avatar
yeah, check my website.
http://www.calrockx.com/4runner/myru...ds/offroad.php go to the andymod section
Old Nov 15, 2005 | 12:04 AM
  #456
Citykid's Avatar
Ahh, that is exactly what I was asking. Thank you brother.
Old Nov 15, 2005 | 09:19 AM
  #457
yabedude's Avatar
Stopped at a local Toy parts department to pick up a couple of replacement wiper blades yesterday as these literally fell off! Anyway, as I walked away I remembered that I wanted to ask them something ... I went back and asked about the (A)TRAC OFF switch that I see in my repair manuals. I asked if such a switch is available for the 2003 Sport edition and whether it's a plug and play thing. I explained why I want it off and he was understanding.
He's not sure if it's a plug and play, but like me, he suspects that the coupler is at the cabin fuse box -- I did see some sort of a coupler there and considering there are many options available this must be one of them (fingers crossed).
Any way, there are two part numbers (made in different plants) and the suggested price in CAD$ is around $80.00:
84988-35040
84988-35010
On January 30th, mypalthetortoise posted that he thought the part number was 84988-35040 which seems to jive with what I've been told by the parts guy.
I'm going to continue my research and probably buy one within a month.
Old Nov 18, 2005 | 02:14 PM
  #458
mike_d's Avatar
sorry to drege up such an old thread, but i ran across this today:
http://www.realtechnews.com/posts/2176
i don't know how real it is, and i can't test it since i don't have a 4th gen. but it may be worth a try, the lexus IS computer may have lots of shared code with the 4runner.
Old Nov 20, 2005 | 09:09 PM
  #459
yabedude's Avatar
I tried twice, but wasn't able to get this Lexus hack to work on my 2003. It may work on newer models.
Old Nov 22, 2005 | 09:49 AM
  #460
yabedude's Avatar
84988-35040
84988-35010
Just talked to the regular Toy parts guy I use and he explained that in order to use that 4th Gen switch an additional computer device is also needed. Not including the change in wiring harness, the cost (with discount) was going to be CAD$1354.86! I'm not persuing the factory switch further so it's back to trying to figure out how to apply the ANDYMOD™.
