vent visors?
Old Jul 9, 2003 | 08:16 PM
4RunninGregg's Avatar
Guest
vent visors?
I just got some vent visors and im kinda lost on how to get them on... there the adhesive kind... but they seem to be to long....? someone said i might need to take off my mirrors or something... any one know a little bit more bout this then me let me know thanks
Old Jul 9, 2003 | 08:18 PM
TDiddy's Avatar
Welcome newbie.....
I have ventvisors on my 4R, and have had them on other vehicles too and have never had to take off a mirror. You may want to check to make sure you have the right part number.
Old Jul 9, 2003 | 08:19 PM
Guest
there for 96-00 i have a 96 so they should fit...
Old Jul 9, 2003 | 08:20 PM
TDiddy's Avatar
Yeah, if that's the case they should fit without haveing to take anything off!
Old Jul 9, 2003 | 08:23 PM
Guest
ne body else....
Old Jul 9, 2003 | 08:26 PM
CMUpike's Avatar
hey, i'm not trying to sound like a smartass, but maybe you have them backwards? like perhaps you're trying to put the vent visors from the left side on the right side, that may make them seem like they're not fitting. i guess it may just be worth letting the obvious out.
let us know how it goes
Old Jul 10, 2003 | 11:57 AM
Guest
so i have a 96 4runner... and i just got vent visors... do i need to take off the side mirrors and fit them under.... or does somebody know how to do it otherwise?
Old Jul 10, 2003 | 12:09 PM
Guest
i just got the back windows on... all i need to do is get the front ones on.... but they seem to long... i think i need to take off the mirror? does that sound right to ne body?
Old Jul 10, 2003 | 12:18 PM
Yoter's Avatar
Guest
There are tight fit and regular fit type visors as ive seen. I have the type that fit over the mirror on my 91. If they seem to long then just simply pull the access cover on the inside of the door for the mirror. back the three screws off just enough to fit the visor behind the mirror assy.. You will be able to tell if they work or not. Its easy. Have fun, take pics for us.
Old Jul 10, 2003 | 12:27 PM
Guest
behind my mirror in my car are tweeter holders... there stock?
Old Jul 10, 2003 | 12:29 PM
Yoter's Avatar
Guest
The cover the tweets are mounted into should come off. Below that should be the three mounting screws for the mirror assembly.
Old Jul 10, 2003 | 12:39 PM
Guest
so is this a dangerous operation or what? should it be pretty easy?
Old Jul 10, 2003 | 12:45 PM
Yoter's Avatar
Guest
Be careful being on my 91 it is only a simple cover. On yours it may have fragile clips. Just be careful. You should be able to place the visor on the door starting at the rear to get an idea of if it would lay flat and look correct without removing your mirror.
Old Jul 10, 2003 | 12:47 PM
Guest
here goes nothing
Old Jul 10, 2003 | 12:51 PM
Guest
i got it off... there looks to be 3 bolts... do i need to listen them?
Old Jul 10, 2003 | 12:57 PM
Yoter's Avatar
Guest
yeah, you should only need to back them off to the end of the thread but shouldn't have to take them all the way off. Slide your visor in and see if it fits. If so then its on you to make sure its straight. I admit my pass. side was not perfectly straight.
Old Jul 10, 2003 | 01:12 PM
Guest
there on they look good so far they look perfect thanks guys
Old Jul 10, 2003 | 01:14 PM
Yoter's Avatar
Guest
right on! glad to have helped yuh, enjoy em!
kawazx636
Oct 6, 2021 03:03 PM
ToyotaMD
Aug 17, 2018 10:16 PM
coryc85
Dec 5, 2015 08:42 AM
stanz
Oct 30, 2015 10:33 AM
gyroscope7
7
Sep 27, 2015 08:39 PM
