Vent circulation problem
Old Mar 23, 2016 | 03:17 PM
Steven675r's Avatar
Hey, I have a 1998 Tacoma V6. When i turn the fan control knob all the way up the air seems to only blow through the defrost vents and the driver side(not alot of air) vent. Thats it, when i try to switch it to the floor or any other mode it clicks but nothing happens. The heat works fine. I've heard it could possibly be a vacuum leak?? Thanks
Old Mar 24, 2016 | 12:04 AM
wyoming9's Avatar
Red face
Dirt or mouse nest in the duct work
Which could be keeping the doors from moving like they should
Old Mar 24, 2016 | 07:44 AM
Malcolm99's Avatar
The 98 Taco is cable not vac, objects can fall down the defrost and block/jam the blend door flap, there are little gears in the knob causing the clicking as they can't move the cable, also the cable itself could have failed or got kinked, I think the blend door is behind the stereo unfortunately but you may be able to access it buy removing the lower dash.
Old Mar 30, 2016 | 06:49 PM
Steven675r's Avatar
will check under the dash then. Thanks for your replies.
Chris Parker
Mar 16, 2016 05:51 PM
Ridge
Mar 9, 2016 08:47 AM
COMPLETENOVICE1983
Mar 5, 2016 11:45 AM
cpljenkins01
Feb 24, 2016 05:55 PM
