V8 SuperCharger is out
Taken off Concelli's site. Est price is around $4000, of course if you have connections with the dealer, you can get it much cheaper than that! This will work only on the Tundra/Sequoia V8 1UZ engines. From what I see so far, it is CA legal too!
NEW FEATURES
SUPERCHARGER DETAILS
TRD V8 Supercharger features new exclusive system enhancements dedicated to improving efficiency and performance
such as an internal bypass system to ensure proper idle and a dynamic belt tensioner designed to self-adjust to the optimal
belt tension.
Includes a supplemental injector that creates an "intercooling effect," permitting higher boost levels for increased efficiency
and enhanced power and torque.
Provides fuel map and spark timing tables fine-tuned by TRD engineers to offer peak engine
performance.
Features Multiple Spark Discharge that aids combustion efficiency at all RPMs.
TRD EXCLUSIVE ENGINE MANAGEMENT SYSTEM
PERFORMANCE STATISTICS
APPLICATION & PRICING
Up to a 50% increase in horsepower (maximum gain is 235 HP vs. 353 HP at 5200 RPM)
Up to a 50% increase in torque (maximum gain 239 lb.-ft. vs. 359 lb.-ft. at 5200 RPM)
Torque increases 32% at 2800 RPM
Boost pressure: up to 7 psi
INSTALLATION DETAILS
Estimated Installation Time: 6-8 hours
Detailed installation instructions included in every kit.
TRD 4.7 L V8 SUPERCHARGER Boasting up to a 50% increase in horsepower and 50% increase in torque over stock, the TRD 4.7L
V8 Supercharger demonstrates the most advanced engineered bolt-on unit developed by TRD.
TRD pairs a powerful Eaton M90 assembly with an exclusive fine-tuned TRD Engine Management System for optimal
power and efficiency over the complete RPM range.
Constructed of modular cast aluminum, the supercharger offers great durability and features OEM quality parts and a
professional powder coated finish.
WARRANTY INFORMATION
When installed by a Toyota dealer, the TRD V8 Supercharger warranty works seamlessly with your Toyota new vehicle
warranty. If installed by a Toyota dealer on a vehicle with any of its new vehicle power train warranty remaining, you will
receive either 12 months, unlimited mileage from the date of installation or the remainder of the new vehicle power train
warranty, whichever is longer. Units installed by do-it-yourselfers have a 12-month, unlimited mileage warranty.
NEW FEATURES
belt tension.
performance.
Excellent... good to see they got it worked out. Last I knew there were concerns about how the Tundra would hold up to the extra power (I want to say the concern was with the tranny, but I don't remember for sure).
Damn, that has some bad a$$ horsepower. That would be sweet to do! I can't even imagine the gains you would get by doing this! Real nice, real expensive, but well worth the investment! :fireman:
Guest
Posts: n/a
performance.
So, does this mean there is a plug in or a replacement for the ECU? All that data is kept internally on the computer so i'm assuming it either comes with some kind of plug-in chip or the computer must have some kind of EPROM that can be flashed or something. I guess that rules out an 'at-home' install if it has to be flashed.
I'm a computer geek, this is the first thing that sounded 'off'.
J.
performance.
J.
Originally posted by Philly
Now if they would put a V8 in the Runner, OMG would that be incredible. Here's to dreaming.
performance.
J.
performance.
J.
Originally posted by jalaber
Many people believe that Toyota will put the V-8 in the 4th gen 4R coming out in 2003. 4R + V-8 + TRD Supercharger...WOW!
He also said that the port would have the info in Aug and he had a contact that was going to give him a pix if I was interested and wanted a copy.
Originally posted by Mohamed
TRD pairs a powerful Eaton M90 assembly with an exclusive fine-tuned TRD Engine Management System for optimal power and efficiency over the complete RPM range.
Just for kicks ... Has anyone ever tried to stuff one of these 4.7 V8's in a late model 3rd gen before?
Could it even be done? A 4.7 V8 with a TRD S/C stuffed into a 4Runner ... LOL ... the power would be crazy.
I took a look at the engine bay of a 3rd Gen runner and the V8 block, it's a serious cramp fit, but I guess anything is possible, the bay though would have to be banged the hell out of to make room for the block. But I look at other componets and wonder how they would fit like the steering components and such. I commend anyone that makes it fit.
Co-Founder/Administrator
When I spoke with Matt, it's a V6 specked out to 4.0.
Basicaly a 3.4 bored 30 over.
It's suppose to be available in the Taco later, but not right away for the 2003s.
Not sure, but I don't see why that same one would not be available in the '03 Runner later.
Probably will be.
Corey
Probably will be.
Corey
From motortrend---->> http://motortrend.com/future/index.html
2003 Toyota 4Runner: The all-new 4Runner shares its platform with the Lexus GX 470, growing significantly in size and offering more content. Expect a 240-hp V-6 to be standard, with a 235-hp V-8 optional.
I gotta admit those Toyota 3.4 V6, especially on Taco's are very torquey and if not powerful, especially when you free the exhaust on those things like my friend did. I can also tell you a stock Taco will woop my Tundra.
I think it would be close..I had a 99 tacoma and a 2000 tundra v8 and i sure miss the power of that v8. I love my 4runner but my tundra would definitely leave it and my old tacoma with a 3.4 in the dust..
That doesn't make sense, how is a V8 going to have less hp than a V6? Well obviously the choice would be a V6, less gas and more power.
Here's a question, if you did have your 3.4 engine bored 30 over, would the TRD/Eaton Supercharger still work on it or is it designed only for 3.4L specs.?
Thanks
Steven.m.paulk
Jun 7, 2020 10:45 AM
LCE_Performance
Oct 1, 2015 01:03 PM
anniesball
10
Sep 15, 2015 05:41 PM
anniesball
Sep 9, 2015 09:55 AM
anniesball
Sep 7, 2015 11:20 AM
