Upper Idler pulley on 3.4L
Old Sep 10, 2004 | 08:59 PM
Dan_90SR5's Avatar
Can anyone tell me what the upper idler pulley on the 3.4L (5VZ-FE) bolts to? Does it just bolt to the rear timing cover (the meatal plate that bolts to the heads behind the timing gears) or does it bolt straight threw that and into the block?
I know this might be a rather odd question, but it's very important for my 3VZ-FE head swap.
Maybe someon has access to the microfiche and a good viewer......or maybe the Toyota manuals on CD??
Old Sep 11, 2004 | 06:47 AM
ErikB's Avatar
The rear timing cover is too flimsy to support that bearing. I just replaced one about a month ago so I should remember, but I don't.
It either bolts to the block itself or to the lower intake (aluminum). I want to say its the block, but I can't say for sure...
Old Sep 11, 2004 | 07:45 AM
Dr. Zhivago's Avatar
Away
I'll be replacing my timing belt in the next couple of weeks. So I can tell you then...
Peace.
G
Old Sep 11, 2004 | 09:14 AM
Dan_90SR5's Avatar
Peace.
G
Thanks alot. I would like to have the info before then, but will take what I can get. I'm doing a head swap on the 3.0L and am at a stand still because of the timing. I have the intake so I'll take a better look at it. If it bolts into the block, is there any way that you can get me a picture? I'd appreciate if so.
Old Sep 14, 2004 | 05:19 AM
MTL_4runner's Avatar
This like might be what you are looking for.....
http://www.lieblweb.com/tacoma/Mecha...cans/index.htm
Old Sep 14, 2004 | 06:26 AM
Dan_90SR5's Avatar
I've seen that much and it didn't help a whole lot. I appreciate the effort though. What I need to know is if it bolts to the engine block or not......and if possible some pictures. I might just have to go out to the salvage yard in the next town over to see if they have a 5VZ-FE block that I can take a look at. The local ones don't have any newer Toyota 4Runners/Tacomas/T100s.
Old Sep 14, 2004 | 07:42 AM
I do think your best bet will be to hit the junkyards and look for yourself because it will be difficult at best to take a clear digital pic of what you want.
Is the tensioner in a different place on the 3.0L? should be the same setup?
Old Sep 14, 2004 | 08:44 AM
Dan_90SR5's Avatar
The tensioner on the 5VZ-FE and 3VZ-FE are hydraulic. The tensioner on the 3VZ-FE uses a spring. Also the timing belts are different in the length and amount ot teeth. Two tooth difference. Length isn't a big deal. The upper idler on the 3VZ-E bolts to the intake and on the 5VZ-FE and 3VZ-FE they bolt up at the same place......I just need to find out where that it and get the idler pulley.
Old Sep 14, 2004 | 09:48 AM
.......sorry meant the idler not the tensioner.......been a long day already...
Old Sep 14, 2004 | 08:54 PM
DarylD's Avatar
The upper idler pulley mounts to a bracket that attaches to the block . Sorry no pics.
Old Sep 14, 2004 | 08:57 PM
Dan_90SR5's Avatar
You are the freaking man. I'm going to have to see if I can aquire one of those brackets. I guess I need to buy a book for the 5VZ-FE engine too.
Old Sep 14, 2004 | 10:03 PM
DarylD's Avatar
I just happened to tear down a long block yesterday .If you were local you can have it . I just don't have any extra time to ship.
Old Sep 15, 2004 | 08:49 AM
Dan_90SR5's Avatar
Is there an amoutn of money that might make it worth your time to ship it? Or possible will some one else on here in WA pick it up and ship it?? I need that part.
Old Sep 15, 2004 | 08:55 AM
Dan_90SR5's Avatar
As a matter of fact, it you were willing to sell me that bracket and both the front and back timing covers off that engine I'd really appreciate it. I understand that you're busy, but I need those parts to finish my project.
You can read about it if you like:
https://www.yotatech.com/forums/show...083#post408083
I'f not I'll look for a local guy that can come pic the parts up.
Old Sep 15, 2004 | 07:49 PM
DarylD's Avatar
Dan PM me your address I'll try to get that in the mail for you in next day or 2,unless someone can pick it up . The timing covers are missing . Daryl
ladybugRC
458
Aug 21, 2020 10:41 AM
moparbay
Oct 6, 2015 09:24 AM
Obmi
Oct 4, 2015 11:30 AM
LCE_Performance
Oct 1, 2015 01:03 PM
bradahman
Oct 1, 2015 09:24 AM
