Unlocking Hub conversion from ADD 2001 Tacoma
Old Jul 27, 2004 | 06:40 PM
MvCrash's Avatar
I have a 2001 Tacoma with the ADD system. I have a friend who tells me to remove the auto locking hubs and replace them with manual hubs. He insists that this takes alot of wear off the 4x4 components and that I will get better gas mileage.
Has anyone converted their autohubs to manual ones and if so which hubs did you use? My last truck 8822RE had Warns and they were fine. I can do the work myself, but was wondering if its worth the trouble.
Thanks in advance,
MV
:pat: :pat:
Old Jul 27, 2004 | 06:46 PM
RobT2k's Avatar
Your friend is right. Do a search, you'll find out everything else you need. It's not gonna be as cheap/easy as the older toyota hub swaps. $500+ would be a good ballpark, if you get a deal on the parts from a junkyard. ORS kit is around 1k
Old Jul 28, 2004 | 07:40 AM
ncoffey's Avatar
You also need a hydraulic press from what I understand. I'd like to do the conversion myself, but for $1500CAN I dont think it's worth it unless you're getting into lifting...
Old Jul 28, 2004 | 11:05 AM
calg3's Avatar
Steve has the writeup on his website:
http://fastq.com/~sschaefer/junk_yard_manual_hubs.html
Old Jul 28, 2004 | 11:09 AM
superjoe83's Avatar
if your truck does not have abs, then you dont need a press
westonian18
May 1, 2020 06:38 AM
Ironmike4x4
Feb 3, 2016 11:13 AM
jaretstuff
Aug 4, 2015 02:08 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
mengquis
Jul 13, 2015 10:39 AM
