Tune up and Maintenance?
Old May 10, 2004 | 11:22 PM
Grim13's Avatar
Cool Tune up and Maintenance?
My ol' faithful has done me well for the past 6 years. I have done a major $300 tune-up @ 30K (way too early, I know - should've done it @60k)
- break pads replace
- oil filter, oil, airfilter, gas filter replace
- new shocks, spark plugs
- alignment, tire rotation
- transmission fluid replace, radiator flush
@90K
- timing belt replaced
- water pump replaced
Now's she's hit 130k and still runs flawlessly. I've recently changed the airfilter and another alignment, and have done puntual oil changes. Anybody have other suggestions or what kinda potential problems I may run into with a high mileage? Also if there are some maintenance that I've missed?
Only minor glitch I have would be a high pitch noise that I hear when I release the accelerator. This goes away when she's warmed up. Also, a minor vibration of the steering wheel (had alignment done twice in a row, but still remains).
Old May 11, 2004 | 09:06 AM
jx94148's Avatar
Make sure that whoever is balancing your tires uses a lug centric balancer, not hub centric. That might clear up your steering vibes. Keep your balljoints, u-joints and slip yokes well greased. Rear gear oil? Sounds like you've been pretty meticulous with the maintnence.
Old May 11, 2004 | 03:16 PM
Paul H.'s Avatar
Have you replaced your diff. oil and transfer case oil recently?
Old May 11, 2004 | 03:19 PM
jimbo74's Avatar
that what i was thinking..... replace the steering box oil (either manual or power) replace the diff oil (front/rear if applicable)
if it is vibration-thats tire balance/out of round condition, not alignment
Old May 11, 2004 | 03:22 PM
bike4miles's Avatar
Flushed your radiator recently? Remember to used distilled water when you re-fill it.
Old May 11, 2004 | 03:42 PM
Glenn's Avatar
Don't forget to check/adjust muffler bearing clearance. It's something that even the most experienced Toyota technicians overlook.
Old May 11, 2004 | 05:01 PM
bike4miles's Avatar
Also very overlooked is the headlight fluid leval and the nut behind the stering wheel.
Old May 11, 2004 | 05:38 PM
Grim13's Avatar
thanks for the input, all. I'll check all that's mentioned. I think they've drained all the fluids, when they chained the timing belt and water pump (is that a norm when they do them?) I better check my receipt. I've gotten that done at the dealer and cost me $800 @90k
ladybugRC
458
Aug 21, 2020 10:41 AM
primordialbeast117
Dec 19, 2015 12:23 PM
Truckwithoutaname
Oct 3, 2015 03:41 PM
the_supernerd
Oct 1, 2015 09:20 PM
mordell
Sep 12, 2015 10:13 AM
