TSB for my 02 Sport
Old Aug 18, 2003 | 08:13 AM
2002 SportEdition's Avatar
TSB for my 02 Sport
Hi guys,
I just stopped by the local Toy dealer for a check up on my "Door weather strips". It keeps loosing out/dropping down some sort like that, if I stretch it and put it back it will likely stay there for a few days then the same things happen again.
So they checked it then told me that it is covered under the TSB. So they ordered it for me.
Hope I can share this.
Old Aug 18, 2003 | 11:02 AM
socaleric2002's Avatar
maybe you can post the TSB # so that others with 02's can checkt o see if they fall under the TSB
Thanks
Old Aug 18, 2003 | 12:22 PM
Yeah, I'll ask the dealer for the TSB number when I bring my rig in for the replacement.
Thanks.
Old Aug 18, 2003 | 12:34 PM
Sparman's Avatar
Same story here
Same problem with my 02. First it was the ft pass door, I took it in, was good for about 6 mos, and its crumby again - pulling from the top rear corner like the seal is too small.
Now 3 of the 4 doors are affected.
I'm wondering if it's worth taking it in or devising a fix on my own....
Old Aug 18, 2003 | 12:38 PM
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
Sparman,
If its covered under a TSB, then let the dealer do the work for free.
2002 SportEdition,
Does this effect only 2002's or are there other years covered?
Old Aug 19, 2003 | 06:28 AM
Originally posted by rwmorrisonjr
Sparman,
2002 SportEdition,
I'll ask the mechanic when I bring my rig in for service. They have to order the parts, so maybe I'll get it done next week.
Old Aug 19, 2003 | 07:22 AM
hillbilly's Avatar
Anyone else out there know what TSB # this is or if it covers models other than '02. My '01 driver door has this same problem....
Old Aug 19, 2003 | 09:06 AM
Echo5059's Avatar
Hey Guys,
I immediately noticed the same problem with my '02 Sport shortly after bringing it home. The front passenger side door and rear drivers side door weather stripping was drooping a falling off. I took it to one dealership and they just applied more adhesive to the weather stripping. This worked for about a week and the problem recurred. I took the 4 Runner to another dealerships and I was informed that the weather stripping was too short and it was a factory defect. They had to order the replacements and they did replaced them under warranty. I was not told anything about a TSB though.
Echo
Old Aug 19, 2003 | 09:14 AM
Echo
that sounds like a TSB since they are aware of the issue and are already fixing it without giving you any problems. the # would be good so we could all get some new weatherstripping
Old Aug 20, 2003 | 05:26 AM
hillbilly's Avatar
*** bump ***
Can anyone shed some light on the TSB # for this??
Old Aug 26, 2003 | 06:37 AM
hillbilly's Avatar
*** bump (round two) ***
Anyone have any more info on this TSB yet?? I contacted my dealer yesterday about my sagging door seals. They ordered 2 seals for the front doors, but said they needed to verify my rig fell under the TSB. I like to have details (TSB #, info) before the works starts just in case they try to give me the run around or try making me pick up the tab AFTER the works already done. They haven't provided me with any TSB info yet....
Are the rear doors covered as well??
Old Aug 26, 2003 | 07:37 AM
Andrey's Avatar
I have the same problem on my rear driver's side door. My local dealer replaced weather stripping under warranty 2 times already. I have 2001 4Runner SR5 by the way...
-- Andrey
Old Aug 26, 2003 | 07:39 AM
I just dropped off my rig this morning for the service, I asked the service attendant about the TSB number but he didn't know. I asked if the technician knows, he said maybe. He told me that they will write the TSB number on it when they are done servicing. I sure will ask for the TSB number for you guys. I'll pick it up today after work.
**They said that they will replace all 4 doors.
Lam.
Old Aug 26, 2003 | 07:49 AM
calrockx's Avatar
yep, same problem here. i haven't really had any negative consequences yet, but i'll get it fixed if it's no big hassle
Old Aug 26, 2003 | 07:56 PM
Got a TSB number
Hi guys,
I picked up my rig today, the dealer replaced all 4 strips and other necessary stuffs for the doors. Everything looks good now. here is the TSB number: BO001-03 (B-O-Zero-Zero-1 - Zero-3)
Good lucks,
Lam
Big Little Bear
230
Nov 13, 2023 11:42 AM
jacked_72
Sep 14, 2015 03:31 PM
ahriman
Aug 1, 2015 10:38 AM
1996Taco
Jul 20, 2015 12:02 AM
