Trouble Removing Steering Rack
Old Jul 6, 2010 | 08:45 PM
sprockmember's Avatar
I have two problems, any help would be awesome. My first problem is the unpressurized line to the rack. I cannot get it off. I've tried line wrenches, regular wrenched, I've even tried the locking pliers (I thought I'd just replace the fitting once I got it out). Any suggestions?
And I was also wondering what other bolts/nuts I need to take out. I know... I know... I need an FSM. Please take a look and tell me what to hit up next.
Thanks. -Nels
Old Jul 6, 2010 | 09:09 PM
scuba's Avatar
FSM
http://www.ncttora.com/FSM/2003/index.html
Old Jul 6, 2010 | 09:37 PM
So... as it looks to me, I've removed the one bolt that would allow my rack to drop (the one towards the bottom of the picture. Eh?
Old Jul 7, 2010 | 04:40 AM
scuba's Avatar
Page 2
Last diagram.
http://www.ncttora.com/FSM/2003/Repa.../ntsc/remo.pdf
It only looks like you've got one of the B bolt out, not A
Old Jul 7, 2010 | 06:21 AM
Wow... I didn't see that page... it looks like you're right. Thanks!
Old Jul 7, 2010 | 08:28 AM
BajaRunner's Avatar
I'd just cut the de-pressurized line. You can just run 3/8" transmission hose back to the pump.
Old Jul 9, 2010 | 09:49 AM
03MUDfunyota's Avatar
Ne of you guys know the bleed procedure for power steering system for a 03 tacoma 2.7L, 4x4? {installing new rack, pump and lines}
Old Jul 9, 2010 | 11:07 AM
PismoJoe's Avatar
P/S system pretty much bleeds itself, the FSM posted by scuba has a detailed description
Old Jul 10, 2010 | 03:04 PM
Ya thats what I thought, put 6" fabtech lift in I'm starting to think the pressure extention line that they gave me might have a kink in it. Blown three pumps so now I'm replacing the pump lines and rack, just don't want to put it all in and have the same problem. By blowinhg the pumps, I mean to say, I finished lift install fired up tried to bleed pump blew, replaced fired up blew again, same with the 3rd. I can't even get started on wheel turning. Figure either line is kinked or the rack is done.
icentropy
Sep 16, 2020 02:47 PM
delmert
Sep 30, 2015 04:34 PM
priest16
15
Aug 6, 2015 07:43 AM
defrag4
Jul 31, 2015 10:50 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
