Tricking Auto Tranny for dyno?
Old 09-12-2004, 10:41 AM
Weasy2k's Avatar
I am about to goto dyno to test my new setup (10psi with WI), but i am wondering if its possible to prevent the tranny form downshifting like crazy all the time. I was thinking of taking the kickdown cable out as well....any other advice?
Old 09-14-2004, 04:48 PM
Transdude's Avatar
Removing the kickdown cable will have zero effect on keeping the trans from downshifting, as it has nothing at all to do with shift timing- only throttle pressure, which only effects shift feel.
What removing the cable may do is damage the transmission due to the high torque demand coupled with low throttle pressure.
What actually determines what gear you are in is the computer. This is accomplished by it applying voltage to solenoids in the transmission in a specific pattern for each shift.
What I would recommend would be to disconnect the transmission wiring harness from the trans and apply voltage to shift solenoid 2, which will give you third gear only- this is the 1:1 ratio that dyno tests are made in.
-John
Old 09-14-2004, 05:03 PM
Transdude's Avatar
Also Johnny, feel free to contact me if you need info on which pin the voltage needs to get to.
-John
Old 09-14-2004, 11:40 PM
Weasy2k's Avatar
Hah thanks John! I was just gonna call you on wednsday (today for some people) in a few hours
I had thought the same thing as well but wanted to call you for verfication
Thanks man...the valve body rocks!
tinigunner11
08-14-2015 01:19 PM
Iceman4193
07-15-2015 04:48 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Tricking Auto Tranny for dyno?
