TRD's 5 PSI Pulley for the V6 Superchargers
Old Aug 27, 2004 | 06:09 AM
pfdaxe's Avatar
Originally Posted by Gadget
There are two separate issues with the TRD supercharger. First is the high RPM lean out problem. That is what the larger injectors and fuel pump along with the fuel controller addresses.
The other is the HG/LR-Ping issue. That is not a fuel issue. At that engien speed and manifold pressuure that it occurs the stcok fuel system can supply alll the fuel the engine needs. The fix for that is retarding the ignition timing.
If your ONLY concern is the HG/LR-Ping and have absolutely no concern about the High RPM Leanout and its accociated engine damage, then no, you do not need fuel mods, you just need to retard the timing to supress the HG/LR-Ping.
On both of my trucks I have chosen to fix both problems and that is what our URD kit is geared for, a TOTAL solution.
Gadget
Thanks for the clearification G-man! I'm still looking at getting your kit sometime in the very near future
Old Aug 27, 2004 | 06:13 AM
SLC Punk's Avatar
I installed the TMC 1.1 because I am most concerned with the pinging. I haven't had any fuel starvation problems (4,500 ft above sea level).
I am still planning on getting the URD kit, but its a little out of my price range right now. So the $100 TMC 1.1 was a better choice.
Old Aug 27, 2004 | 06:24 AM
Gadget's Avatar
I wish you would of gotten the FTC instead of the TMC1.1. The TMC1.1 is a fixed retard based only on RPM. So it will retard timing even when you don't need it to. This can make it a little sluggish and affect fuel economy.
The FTC is fully programable and you can set the amount of retard based on manifold pressure and RPM, so it will only retard when you need it at a given boost pressure and RPM. This way it will not impact fuel economy.
You will also have the fuel controller installed for when you later upgrade the injectors and pump. It would of saved you money in the long run and have your truck running better now.
Gadget
Old Aug 27, 2004 | 06:35 AM
havic's Avatar
What engine problems/damage can come out of High RPM Leanout?
Old Aug 27, 2004 | 08:24 AM
  #25
Gadget's Avatar
Catostrophic engine failure.
Gadget
Old Oct 14, 2004 | 06:42 AM
  #26
Amir904's Avatar
How do you know one is experiencing High RPM Leanout?
Old Oct 14, 2004 | 06:57 AM
  #27
Gadget's Avatar
You use one of the three different wide band units from www.URDUSA.com
Gadget
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Steven.m.paulk
Jun 7, 2020 10:45 AM
justdifferentials
14
Jun 11, 2017 08:36 PM
Jdgarrison
Oct 1, 2015 05:22 PM
LCE_Performance
Oct 1, 2015 01:03 PM
