TRD Supercharger - Gen 1 vs. 2
Old Apr 11, 2003 | 09:16 AM
snappy's Avatar
Does anyone know the production dates for each of the 2 superchargers?
Aside from aesthetics, are there any significant performance differences between the 2?
Thanks!
Old Apr 11, 2003 | 02:12 PM
Bay Runner's Avatar
Hey snappy,
Have you checked Gadget web site yet? You'll find lots of info on superchargers Gen 1 and 2.
I have a Gen 2 supercharger on my 2000 4runner and you'll see a good difference on power when you install it. The only problem that I have with it is pinging. You'll also find articals in Gadget's site on how to fix the ping problem.
Good luck.
http://www.gadgetonline.com/4Run.htm
Old Apr 11, 2003 | 03:21 PM
Vato Loco's Avatar
I heard that the 1st Gen gives you 10hp more than the 2nd or something like that
Old Apr 11, 2003 | 03:38 PM
Gadget's Avatar
BS!
Gadget
www.GadgetOnline.com
Old Apr 11, 2003 | 04:13 PM
PhxTRDRunner's Avatar
..I thought I read somewhere that they gen 2 gave 5-10 more hp...
Old Jul 25, 2006 | 09:46 AM
---Camrazy---'s Avatar
Revived this thread, just to see if anyone knows what the difference is..... I am planning a swap using the 3.4 and have a Gen1 SC lined up but want to know about it....
Thank you
Milt
Old Jul 25, 2006 | 09:54 AM
Gadget's Avatar
The only differnce is the casing design. Magnuson improved their casting ability and instead of making 3 different castings that are latter bolted together, it is now one casting. This reduces production costs and eliminates some of the labor needed for final assembly.
Both versions use the Eaton M-62 supercharger turned at the exact same ratio to engine speed so the same amount of air is pumped.
Once you shut the hood you have no idea what version you have so it makes absolutely no difference. With the hood open, the later version may look nicer.
I have two Gen I Superchargers, one serial number 0032 and one serial number 0299. They seem to still be working pretty well after all this time. Of course both are U-Tuned...
Old Jul 25, 2006 | 10:13 AM
RunnerUp's Avatar
not to hijack, but what all is required besides the supercharger to effectively run it on a 4runner with auto tranny and 110k?
Old Jul 25, 2006 | 10:28 AM
Gadget's Avatar
That is an easy question. I recommend the URD Supercharger Performance Upgrade Kit and a good tune:
http://www.urdusa.com/index.php?cPath=79_80
I also recommend a transmission valve body upgrade. The best place for that is Import Performance Transmission in NJ. You can pull the valve body, overnight it to them and install it when it comes back modified.
Gadget
Old Jul 25, 2006 | 10:38 AM
RunnerUp's Avatar
thanks gadget
Old Jul 25, 2006 | 12:25 PM
mastacox's Avatar
Mmmmm, I'm going to be getting myself one of those very soon...
Old Jul 27, 2006 | 11:04 PM
Thank you Gadget...
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
suppra87
Jul 15, 2021 05:15 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
anniesball
10
Sep 15, 2015 05:41 PM
anniesball
Sep 9, 2015 09:55 AM
