Transmisson Fill/Drain Torque
Just replaced the transmission fluid (5-speed) in my 2003 Tacoma with Amsoil....I definately notice a difference in shifting, I am quite surprised.
Does anyone know the torque spec for the drain and fill plugs. I snugged them up but don't wanna go too tight.
Thanks
Thanks
Originally posted by MTL_4runner
you're always good for a.....
or 2
or 2
On topic: My Haynes (Haynis - because I hate it) Manual says 23 ft-lbs on the filler and drain plugs.
I use the 2 finger torque method. Put your thumb on the head of the ratchet and only use 2 fingers to apply torque. You can crank all you want becuase unless you are schwartzenegger you won't have enuf strength to over-torque anything and strip it out.
A torque wrench obviously works best if you have one.
....most of the time I am just lazy and my method works for me.
Originally posted by keisur
I torque mine until it smokes and then I give it another 1/8th of a turn.
Originally posted by JSharp
Hmmm. I always heard you should tighten things until they start to get loose again, then back off 1/4 turn...
sonorn67
Sep 19, 2015 05:39 PM
larrys93pickup
Sep 17, 2015 07:05 PM
