Toyota=Ford?
Old May 31, 2005 | 06:23 AM
Toyota=Ford?
I was told that the Toyota bolt pattern will fit a Ford (6 lug). Is this true?
I just found a great set of Ford 6 lug wheels at a pawn shop, and they are new and only $250 for the wheels and tires. But they are from a ford.
Ayone know about this?
Thanks
Kent
Old May 31, 2005 | 06:42 AM
bamachem's Avatar
dunno about a ford 6-lug, but a chevy 6-lug has the same spacing for the lugs, but the hub on the chevy is slightly smaller.
Old May 31, 2005 | 07:02 AM
sorry all, I meant chevy 6 lug. My Landcruiser has Aisen manual hubs on the front, Do you think the wheels will work?
Old May 31, 2005 | 07:21 AM
DudeBud's Avatar
they should work
Old May 31, 2005 | 08:34 AM
mastacox's Avatar
Yup, my spare tire is a chevy rim and fits fine.
Old May 31, 2005 | 09:15 AM
cool, thanks for the info.
Old May 31, 2005 | 01:37 PM
Adam F's Avatar
Bolt pattern is the same. Like someone else said, the hole in the center of the rim for the hub is slightly smaller on the Chevy's than on the Toyotas. Also, the backspacing could be an issue since IFS trucks have more backspacing than solid axle trucks. For instance a Toyota IFS rim will not fit a Toyota solid axle truck.
Old Jun 1, 2005 | 11:53 AM
Flamedx4's Avatar
As always when considering rims, the correct backspacing is important. But the center hole on many 6 lug rims are too small. I was given a pair of 6 lug rims for spares and they would not go on the Yota because the center holes were too small. All 6 lug patterns are the same though. Easiest way is to fit one before buying.
Old Jun 1, 2005 | 01:58 PM
Yamaha+Toyota=Fun's Avatar
I am running wheels that came off a cheby. They bolt up just fine. What kinda tires are you gonna buy?
bigjstang
Jun 2, 2025 03:56 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
timmJ
Jul 7, 2015 02:01 PM
