Toyota anti freeze
Old Apr 14, 2004 | 01:46 PM
AF1's Avatar
AF1
Toyota anti freeze
Any reason you have to use Toyota red coolant in our trucks?
Old Apr 14, 2004 | 01:57 PM
ewarnerusa's Avatar
the red is the 100,000 mile long-life stuff. green is less, I don't know how much
Old Apr 14, 2004 | 03:09 PM
Unhappy99's Avatar
Color isn't the issue. Whether or not it contains silicates, borates, phosphates, and other *ates is.
Look for something which specifically states that it does not contain the various *ates. While they cool better, they are abrasives and have a tendency to erode water pump seals quickly. Prestone 5/150 and Havoline Extended life are suitable.
Use distilled water in the mix.
Old Apr 20, 2004 | 04:51 AM
foxtrapper's Avatar
Guest
None. Don't confuse this glycol ether fluid with the acid based long lifed coolants.
Old Apr 20, 2004 | 08:16 AM
Gadget's Avatar
The current rule out there for coolants is a simple one. Use and continue to use what came in it from the factory.
Those "orange" long life coolants are only true long life coolants if they where the first and only coolant used in that cooling system. They use organic acid tech and the way they benifit your engine is that induce a chemical reaction to the surface of the metals which is kind simular to a protect corrosion layer. Sounds odd I know, but it can not do that if it was not the first stuff in there.
Still to this day I can not understand why anyone would want to use something other then what came in there engine. True the off the shelf green stuff, which is fine for your Toyota is cheaper then the Asian Red Toyota stuff, but how often do you flush your cooling system? I do mine every 30,000 and I just do not see how saving $5 every 30,000 is something to really worry about.
Just use what came in it.
Gadget
Old Apr 20, 2004 | 08:43 AM
kyle_22r's Avatar
i don't have the slightest clue what came in my engine. 25 years is a long time ago! it just says not to use alcohol based coolant in the owner's manual.
however when rebuild time comes around(e.g. when i get a job again) i'll fill her up with some toyota red
Old Apr 20, 2004 | 08:48 AM
Gadget's Avatar
Green is what came in your truck. That is the only stuff that used to be available before all this "proprietary" crap came along. Asian Red (Toyota) is compatable with all green systems and is supposed to be a higher quality coolant.
So, is that true, you have not changed your coolant in 25 years???
Gadget
Old Apr 20, 2004 | 08:52 AM
boogyman's Avatar
Talking
Gadget
i could've sworn i saw a post somewhere that said there was no difference between the red toyota coolant and the high life green stuff... i can't really refute anything though cause i don't know where that post was..
Old Apr 20, 2004 | 10:07 AM
foxtrapper's Avatar
Guest
I know in researching it myself, I found there to be no difference. The antifreeze recycling companies I know don't differentiate it. They simply die it the various colors for the various customers, with the base being exactly the same for all of them. I've no doubt Toyota would like you to believe their product is of course special and that you should pay more for it.
Old Apr 20, 2004 | 10:13 AM
Gadget's Avatar
It is generally the same stuff. There maybe more or less of certain ingreadiants. One may have less silicats and other bad stuff then the other. Both are however interchangable.
Check the lable for the ingreadients and chemical break down as to how much or what is in its make up.
I know one thing for sure, the Toyota brand Red has a an additive to help make leaks stand out and eaiser to find.
Gadget
Old Apr 20, 2004 | 10:17 AM
dcampen's Avatar
IIRC, the '04 Owners manual calls for an antifreeze with _no_ silicates.
Old Apr 20, 2004 | 10:36 AM
Astralplane's Avatar
I can't remember where this came from but it does show major differences.
I always wanted to know if anyone has used red coolant and still had repeat hg problems.
I'd post the chart but it says the file is to large, any smaller and you can't read it.
What to do.
Old Apr 20, 2004 | 11:24 AM
kyle_22r's Avatar
Gadget
nahh, i'm not even 25 years old...in fact i've changed it about 3 times in the last 6 months(radiator sprung a leak, then i changed my alternator a month later, filled it up and found the new alt was defective and had to do it again)
Old Apr 20, 2004 | 11:26 AM
mt_goat's Avatar
Yes, that would be interesting to know.
What to do.
Maybe try posting half on one post and half on another.
Old Apr 20, 2004 | 11:56 AM
Old Apr 20, 2004 | 11:58 AM
Part 2
Also I shrunk my original, so if anybody knows where the original can be found please let me know.
Old Apr 20, 2004 | 03:23 PM
kyle_22r's Avatar
don't forget, never, ever, EVER use orange dexcool unless it's required for your vehicle. it turns to sludge and blocks your water jackets.
Old Apr 20, 2004 | 03:26 PM
CTB's Avatar
CTB
Ya, I've seen that GM Dex-Cool stuff do some pretty nasty stuff in the garage I work at during the summer.
To help it's case a little, I think a majority of the problems are from owner neglect. However, I wouldn't ever trust leaving the same anti-freeze in my rig for 100,000 miles without changing it.
Old Apr 20, 2004 | 07:04 PM
ALBPM's Avatar
Arrrrr....Pass me a bottle of the "RED"
Old Apr 24, 2004 | 11:08 AM
kamchatka's Avatar
Another antifreeze option
Gadget
This non aqueous propylene glycol stuff from Evans may also be a possibility expensive though. Makes for interesting reading.
http://www.evanscooling.com/html/npgPls.htm
