Towing With an S-10
Old Jan 24, 2004 | 10:40 AM
Serith's Avatar
Towing With an S-10
I don't know if anyone will know this, but i got a 95' S-10 with the 4.3 vortec engine in it. Would it beable to tow a toyota pickup on a trailer? the pickup is in my sig. I believe they weight about 3,000 pounds, roughly. Does anyone know if these trucks can tow well?
Old Jan 24, 2004 | 11:11 AM
tenfourtyeight's Avatar
I'm pretty sure it will. That is the most powerful engine ever put in an S-10.
My cousin just got a wrecked '95 extracab for $615, and fixed it for about $750, and has a perfectly good truck for tons less than I paid for my truck. The truck used to be a Culligan truck (his dad works for Culligan), and they used to haul several 150lb tanks in the bed, along with a small trailer with the same amount. In all I'd say it was easily over 2500lbs. The rear barely sagged.
Old Jan 24, 2004 | 02:07 PM
kyle_22r's Avatar
i think i'm gonna bite the bullet and work towards a 4.3 swap this summer. then i could drive my truck everywhere to the trails
also as an added benefit, i could probably run 4.10 or other factory gears which are rather cheap and not sought after. i could also buy a factory locking diff from toyota for around 800 bucks this way, too
Old Jan 24, 2004 | 10:49 PM
SLC Punk's Avatar
I don't see why it wouldn't be able to tow 3,000 lbs.
I pulled my friends truck with my 4Runner before it was supercharged and it did it fine.
Old Jan 25, 2004 | 08:02 AM
joez's Avatar
Yes, it will tow it, but i wouldnt go to far with that combo. And your toyota pickup on a trailer will be pushing 4-5K pounds, trailers are heavy.
It generally isnt a good idea to tow something that tall and heavy with such a small truck. It can be done, but make sure the trailer has electic brakes, and you take it REALLY easy. You dont want that load to start telling your s-10 where to go, instead of it being the other way arround.
Personally, unless it was just into town or to a really quick local trail, i woulndt do it. Its not just your life you would be risking, but others on the road. Remember, its not your driving ability you have to worry about, its the other morons on the road.
Brodetski
Sep 30, 2015 11:50 PM
Cycles
Sep 29, 2015 06:37 AM
Odin
Sep 26, 2015 06:56 PM
toyhaulert100
Sep 24, 2015 07:55 PM
83
18
Sep 21, 2015 06:15 PM
