tires screeching
Old Jun 11, 2010 | 02:25 PM
Yukon's Avatar
Turn off the diff lock? The abs light comes on with the diff lock engaged. The tires will squeak because it is locked together and the two wheels cannot turn independantly. You have the 4.30's in pretty sure. If they worked before, i bet they would work now. Try making sure hte diff lock is off. (the light turns off completely not blinking, or solid)
You may have to drive it around a bit to get it to disengage. Post back after youve done that.
Old Jun 11, 2010 | 09:05 PM
PismoJoe's Avatar
Originally Posted by jdm_95_ls
numbers are a04a/a340f
A= 7.5" ring gear
04= 4.56 ratio
A= 2 pinion, open
Any updates??
Old Jun 11, 2010 | 11:01 PM
jdm_95_ls's Avatar
well the diff lock was stuck, so we had to take out the whole differential case out and manually release it since when i tried to disengage it with a flat head it wouldn't budge, now everything is alright. but sometimes the abs likes to kick in.
Old Jun 12, 2010 | 07:44 AM
PismoJoe's Avatar
Nice, I think someone said that you're diff is engaged in the beginning of this thread
Old Jun 12, 2010 | 10:07 AM
  #25
jdm_95_ls's Avatar
yup thanks for whoever gave that suggestion, i thought i had unlocked it when i put it back on the first time but i guess it got pushed back in. any suggestion about the abs now? would i need new sensors?
1uzRunner
63
Nov 10, 2018 03:58 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
AkitaDog
Sep 3, 2015 09:01 PM
128keaton
Sep 3, 2015 05:09 PM
matthew138
Sep 3, 2015 08:21 AM
