Tire size
Old Sep 19, 2002 | 10:14 AM
Question Tire size
Does any gen 3 owners know what is the largest tire size on 16in rims with out any lift?
Just wondering
Del
Old Sep 19, 2002 | 10:25 AM
snoozer's Avatar
265/75/16 or 275/70/16
Old Sep 19, 2002 | 11:30 AM
Hey the 265 vs 275 is the width of the tread right?
And the 75 vs the 70 is the height of the tire?
How do each affect mileage/performance?
Old Sep 19, 2002 | 01:55 PM
rowan's Avatar
no
265/275 is the diameter or height. the 70/75 is a ratio of something to something i think im not sure.
but 285 is 33" so 275 is about 32" 265 is 31" i think
someone correct me if im wrong.
btw, I'd get 31s they look good without a lift. 32's if you can fit them. you should be able to, but it might be really close, or maybe rub a bit.
Old Sep 19, 2002 | 02:03 PM
snoozer's Avatar
265, 275, 285, etc. is the width. The 70 or 75 is a percenatge of the width that equals sidewall height.
265/70 = 31x10.5
265/75 = 32x10.5
275/70 = 31.5x11
285/75 = 33x11.5
My wording on this explanation sucks, sorry.
Old Sep 19, 2002 | 02:25 PM
rowan's Avatar
yeah that doesnt make any sense. 70% of 265 isnt 31"
you do sound like you know what your talking about though.
shark, why dont you go to some tire store and ask them some questions??
Old Sep 19, 2002 | 03:45 PM
Ron(Fla)'s Avatar
The 265 is the tread width in mm's. the 70 is the sidewall height expressed as a percentage of the tread width. So the sidewall height x 2 + the wheel diameter equals the total diameter of the assembly. Some of the tire mfg sites have a more complete explanation and all have charts showing the tire diameters for the different sizes.
Old Sep 19, 2002 | 05:08 PM
rowan's Avatar
okay. now THAT makes sence. thanks a lot.
Old Sep 19, 2002 | 05:20 PM
Hey--
So how does it affect mileage and performance?
A wider tread vs. narrower tread... and taller tire ?
Old Sep 20, 2002 | 11:28 AM
Ron(Fla)'s Avatar
The obvious problem in my answer above is the tread width/sidewall height is metric and the wheel size is in inches. So I just use the charts.
A wider tire could give you less mileage than a narrower tire due to friction, but traction could be better.
A taller tire will go farther in one revolution than a smaller tire, taking you further at the same engine rpm. But this may be offset by using more gas if the engine lugs due to the gearing.
Since I have never done a direct comparison of any of these conditions, I don't know what your actuals will be.
djpg2000
Nov 11, 2020 04:56 AM
jgallo1
Oct 26, 2015 06:39 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
