Tire question???
Old Nov 29, 2003 | 12:04 PM
Guerrero's Avatar
Question Tire question???
I found bumps in my front right tire.
Can someone please tell me what is that?
Thanks in advance
Old Nov 29, 2003 | 02:01 PM
Fink's Avatar
Where are the bumps? Sidewall? Tread?
And what do you mean by bumps..as in rubber bumps like the rubber has pimples..weird to think about..or what?
Fink
Old Nov 29, 2003 | 02:21 PM
Guerrero's Avatar
Fink
Tread...
I can't not see them, but if I pass my hand I can feel them going up and down through the whole tire tread.
My guess is that my shock is going bad.
Old Nov 29, 2003 | 07:42 PM
Tom's Avatar
Tom
i work in the tire business and from what i understand i see that alot. The tread has different hights up, down, up, down all around the tire right. If so, it starts of just slight and i have see it get pretty bad to the point where the customer is complaning of tire noise with an all-terrain tire. Some causes are improper rotation, problem with from end (tie rods, steering idler arms, suspension parts), misalignment, out of ballance tire or it could just be a manufacturer defective tire.
Old Nov 29, 2003 | 08:05 PM
Fink's Avatar
Are your tires still under warranty? If so I would take it to the place you got them, have them look at it and see what they say. Hopefully it may be covered under the warranty as long as there isn't a serious mechanical problem with the rig.
Fink
Old Nov 29, 2003 | 10:26 PM
Guerrero's Avatar
That's the best way to describe it "The tread has different hights up, down, up, down all around the tire"
I hope is a manufacturer defective tire...
Old Nov 29, 2003 | 10:34 PM
Guerrero's Avatar
Fink
I bought my rig in September, the last owner had the warranty with cosco, but I read the warranty and it's only good for the person who bought the tires, too bad because the tires are almost new.
Old Dec 2, 2003 | 06:19 PM
Guerrero's Avatar
Question Please help
What should I do?
Should I rotate my tires front R to rear R and rear R to front R, front L to rear L and rear L to front L ???
Old Dec 2, 2003 | 07:37 PM
Tom's Avatar
Tom
Re: Please help
Originally posted by Guerrero
What should I do?
As for the rotation its your call. My onwners manual for my prelude is front to back and back to front. As for how we do it at work we cross rotate. I never remember which way cross rotation goes because its different from front wheel drive cars to rear/4 wheel drive so i can get back to you on that tomorrow. If you have directional tires just front to back and back to front. One more thing you said that you think your shock is going, if so I'd check it fully because a bad shock could cause improper wear.
Old Dec 3, 2003 | 05:00 AM
Billrunner's Avatar
if you feel the vibration while driving then dump 'em cuz they're trash. Thats all I know.
ps: tire brand?
Old Dec 3, 2003 | 06:36 PM
Guerrero's Avatar
ps: tire brand?
yes, I have vibration when I drive about 60 to 80 after 80 the vibration is not that bad.
TIRE BRAND:
MITCHELIN
X RADIAL LT
P225/75R15
Maybe in the middle of the next year, my plans are to get a lift kit (don't have an idea on what kit should I go for), new wheels and 33" tires. I just hoping that I can make it to next year with what I have now.
Old Dec 3, 2003 | 06:44 PM
Guerrero's Avatar
Re: Re: Please help
I chech my manual for the tire rotation and it said:
Front Right to Rear Left and Front Left to Rear Rigth
Rear Right to Front Right and Rear Left to Front Left
I'm going with that.
Can you please explain me how to check if my shocks are going bad?
Thanks
Old Dec 3, 2003 | 09:09 PM
Tom's Avatar
Tom
Re: Re: Re: Please help
Thanks
Well thats how we would do a rotation at work. As for the shock, I dont know the only time I ever seen any one check a shock was by compresing it and pull it apart, if it hard its good and if its easy its bad. If thats a good way to check it i dont know.
Old Dec 6, 2003 | 11:22 PM
Guerrero's Avatar
Re: Re: Re: Re: Please help
I rotated the tires today, no more vibration in the front, but now I can hear the bad tire on the back. I guees I'm just going to way to see what happend to the other tire that I put in the front, and if that one goes bad too, that's going to be the perfect excuse to buy the whole lift kit
Thanks
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
