Tire Dealer Made Mistake-Should I Ask 4 Replacement?
Old 10-19-2007, 05:43 AM
4Runner4Christ's Avatar
I went back yesterday and they removed the load class E's and put on the C's. The minor rubbing has gone away...the E's must have been slightly larger.
Old 10-20-2007, 02:42 AM
skjos's Avatar
Did you notice much of a ride improvement going back to the 'C's?
I had the same thing happen at my tire dealership, they stuck on E's and I was expecting C's (although I never specified).
The tire change was done at the same time as my OME lift, so I don't know if the increased firmness of the ride was a result of the tires or the lift. However, the ride smoothed out when I decreased the tire pressure to 32psi.
Old 10-20-2007, 01:44 PM
02SE's Avatar
Originally Posted by 4Runner4Christ
I kept the same tire size as my previous Toyo's (LT265/75R 16) and there is minor rubbing, thus the size must be slightly bigger for the load range E's. I am getting the C's put on today, so I'll try to remember to report back if those rub...
I'd be interested to know your impressions of the Goodyears vs the Toyo's.
Old 10-22-2007, 05:06 AM
I did notice an improvement in ride quality when going back to the C's from the E's. I have now gone from the original passenger grade P265's to LT265 C to LT265 E and now back to LT265 C and there is noticable difference in ride quality as you move between these.
Old 10-22-2007, 05:30 AM
  #25
That's a tough one. Goodyear claims: "The key to SilentArmor Technology lies just beneath the tread. Two high-tensile steel belts and a layer made with KEVLAR?, a material that's, pound for pound, five times stronger than steel, helps to give this tire its toughness.
The same layer made with KEVLAR? also acts as a barrier to help absorb road noise for a smooth, quiet, comfortable ride. It's why we like to call this tire ?The Strong, Silent Type.?"
My previous Toyo's, like the Wrangler, were both AT style tires. It does seem like the road noise is slightly less with the Wranglers, but not a lot. As far as the claim for a more "comfortable" ride, I do sense that the ride is a tad softer, although that could be just because I am on new tires with more rubber. I can comment on tread life or off-road/snow capabilities yet. Goodyear does have a very good warranty which includes roadside assistance for the 1st two years. They basically guarantee you will not get stuck :-D and if you do they will come pull you out.
I really liked my Toyos but my mistake was to not take them back in for the free balance & rotate every 6000 miles. They evidently became out of balance, which caused a cupping wear pattern, which let to mucho vibration at highway speeds (which is now gone). I have never rebalanced tires before. Keeping the allignment and tire pressure right has always been enough. The Toyos had plenty of tire depth (except for the cupped areas)even after three years and 40-50,000 miles.
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Tire Dealer Made Mistake-Should I Ask 4 Replacement?
