Timing belt change: 99 4Runner 3.4L
Old Sep 7, 2004 | 06:22 AM
AJatx's Avatar
Do you have to remove the AC compressor in order to remove the timing belt tensioner?
I tried removing one of the bolts on the tensioner and it's starting to strip. So, I'm removing the bracket in order to get a better angle at it.
Also, do you remove the backplate near the tranny/oil pan in order to jam the torque converter so you can untorque/torque the main front hub/pulley bolt?
J
Old Sep 7, 2004 | 08:00 AM
MTL_4runner's Avatar
Yes, I did for the AC bracket and it came out fine.
I rented a chain wrench and used it around the crank pulley (wrap an old belt around to protect the pulley grooves).
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
layifioren
10
Jul 6, 2015 02:26 PM
B. Graves
Jul 3, 2015 04:10 AM
infinityisfive
Jun 16, 2015 06:51 PM
