Time for new plug wires?
Old Jul 18, 2006 | 08:30 PM
LSUMatt1514's Avatar
I've had my plugs replaced a few times, but haven't done anything with the plug wires. The insulation still appears to be in good shape, so I have a hard time believing that they need to be replaced at a certain mileage interval if there are no visible issues. What do ya'll think? I'm at about 156k miles now. Thanks.
Matt
Old Jul 18, 2006 | 08:37 PM
DavidA's Avatar
I have always heard to replace them around 60k. That much electrical activity can break down the conductor over time and increase resistance and reduce spark. Some schools of thought believe 3-4 years in high temp areas of the country.
Just my 2 cents.
Old Jul 19, 2006 | 01:34 AM
jct61765's Avatar
It gets hot under the hood which breaks down rubber. Changing the wires at around 60k is cheap insurance.
Old Jul 19, 2006 | 01:47 AM
Tanto's Avatar
Dang. One more think I need to add to my 60k maint list
Old Jul 19, 2006 | 02:29 AM
phoenixtroy's Avatar
spray them with water, and look for little sparks. IF you see them you should definately replace your wires.
Old Jul 19, 2006 | 02:56 AM
Potomacduck's Avatar
The dealer in town told me that they almost never replace them. Since when didn't a dealer NOT try to sell you something? Some folks say they will last the life of your truck, whatever that means. I sprayed a fine mist of water on the wites at night and didn't see any sparks. I wonder about the resistance question also.
'99 Limited 186,000 miles.
Old Jul 19, 2006 | 03:27 AM
GSGALLANT's Avatar
Just disconnect the wires, and measure the resistance with an ohm-meter. The maximum resistance of each wire is 25 kilo-ohm for my 2002. It should be the same for anyone with a 3.4L.
Old Jul 19, 2006 | 04:16 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Ditto, plus checking for insulation breakdown via the water test or some other, more sophisticated type of an insulation resistance test. No sense replacing them if they aren't bad. Cmon, guys....
Old Jul 19, 2006 | 01:32 PM
Elton's Avatar
lol toyota makes such good parts my sparkplugs wires had 128k miles on them i think the plugs may of been changed once it still ran great just figured it was time for a tune up used factory denso plugs and got a set of ngk wires
Old Jul 19, 2006 | 01:58 PM
Nate C's Avatar
Run them until your engine starts missing... that's what I've done. When a cylinder isn't firing, it's usually time for new wires.
Old Jul 19, 2006 | 02:01 PM
Elton's Avatar
when you do change them becarefull with the clips that hold it on to the coils mine where a little brittle and i broke 2 of them
Old Jul 20, 2006 | 12:12 PM
kepico's Avatar
Elton: I broke one of mine also, where did you get a replacement? Right now I have it zip tied on.
Old Jul 20, 2006 | 12:43 PM
Elton's Avatar
the dealer there not that cheap like 3 bucks each
Old Jul 20, 2006 | 12:47 PM
kepico's Avatar
Great, thanks!
Old Jul 20, 2006 | 05:01 PM
fotorunner's Avatar
I ran mine until May of this year when my 97 started missing. At that point we were probably at about 150,000. They looked like they'd never been replaced. Changed plugs at the same time they had about 40,000 on them.
Old Jul 20, 2006 | 05:59 PM
MTL_4runner's Avatar
Mine are still the originals at over 140k miles. As a mechanic we used to suggest changing them every 6 years regardless of mileage (the year the wires are made are usually stamped on the wire jacket), but I've found the Toyota wires to age much better than other makes. If I start getting a miss (not related to the plugs) or resistance goes beyond spec, I'll probably replace them, but until then, I'll keep running them as is.
voiddweller
19
May 2, 2016 09:10 PM
bigblue82
10
Jul 6, 2015 08:27 AM
ibayne
Jun 26, 2015 06:30 AM
saphirekosmos
Jun 22, 2015 10:26 AM
