ticking noise and oil pressure??
Old 05-02-2004, 10:06 AM
hub_01_69's Avatar
when my truck is warmed up to operating temp and at idle it has this ticking noise...rev it up just slightly and it goes away...all i have is a factory style oil pressure gauge that came with my cluster swap and it reads between the L and the first line on the gauge at idle...i know the 22re is supposed to have lower pressure at idle but should it be that low...seems like it should at least be to the first line...i'm running 5w30 oil maybe 10w30 would clear it up...i dunno...what do u guys think
Old 05-02-2004, 10:08 AM
Fink's Avatar
My pressure is in that same range...between the L and first line. I've got the 6 banger in mine but mine runs great with the oil pressure being where it is.
Fink
Old 05-02-2004, 10:15 AM
hub_01_69's Avatar
yea, mine runs great...remaned engine, installed enginebuilders oil pump, waterpump, timing chain kit, and timing chain cover...just that ticking at idle...i took it to the stealership the other day and the tech that looked at it was like it runs fine but i dunno what that noise is....he wasn't much help at all...
Old 05-02-2004, 10:42 AM
bike4miles's Avatar
My oil presure sit just past the first line when I am diving which has made me a bit concrened since I bout the truck (22re) but it has always been like that. I'ts good to hear you guys have low presure also, mabe it's normal. It will go down to noting if I sit at an Idle for a long time when it's warm.
Old 05-02-2004, 10:52 AM
hub_01_69's Avatar
do you guys hear any type of noise that is different at idle when the pressure is really low compared to when it's not at an idle?
Old 05-02-2004, 06:03 PM
Amkeer's Avatar
Sounds like injector ticks or the normal valve train noise. The normal pressure for a warm engine at idle is between 5-9 for a 3.0 so I would think the 22r is not to far off those specs.
Old 05-02-2004, 06:57 PM
Fink's Avatar
Yeah, the 3.0's are just a naturally noisy engine...I'm used to it now. But I do not notice a difference in noise that is dependant on the oil pressure.
Fink
Old 05-02-2004, 07:14 PM
bike4miles's Avatar
No, nothing more than the constant ticking noise of my over toleranced valve job
bigjstang
08-25-2021 12:41 AM
Odin
07-15-2015 09:28 PM
88yodabasket
07-13-2015 01:32 PM
cars-guy
07-11-2015 07:51 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: ticking noise and oil pressure??
