throwout bearing? clutch noise
Old Nov 26, 2002 | 10:07 PM
instntset's Avatar
I have been browsing the forum for about a month now and finally decided to register as you all see to be a great group of toyota owners. I have a 95 Runner and had the clutch replaced last summer after I tried to teach my girlfriend how to drive a manual and she fried it. (boy was that a dumb idea) I had a very reputable shop put in a new clutch and about a month later a noise started. Sounded like a squeaking fan belt. But I soon discovered that it went away as soon as the clutch pedal was depressed about an inch. I took it back and it was diagnosed as a squeaky throwout bearing. new bearing in...no problems for another month when the noise came back. The owner of the shop said it was rare for two to go bad and told me to watch the way I was driving after he put the next one in(no riding the pedal etc.) The noise went away and came back again yet a third time. This time he inspected the bearing when he took it out and said it appeared to be fine. He replaced the clutch fork as well. no noise for another month. The noise has now come back again for the fourth time and Im getting ready to take it back in. Any ideas as to which direction I could maybe suggest as it is getting really old having my Runner out of commision every month for 4 or 5 days at a time. thanks guys
Old Nov 26, 2002 | 10:46 PM
joshik's Avatar
try another shop
Old Nov 27, 2002 | 12:54 PM
Bentaxel 26's Avatar
Trying a new shop is a good idea, but what you might want to look at is where your clutch is at. you said that when you push down on it it goes away, your clutch my be rubbing against something in your tranny, or a difftent berring is out. there are lots a difftent problems, try taking it to the dealer, a little bit more expensive but they can get you a warrantee.
Old Nov 27, 2002 | 04:54 PM
PhxTRDRunner's Avatar
Curious...did you use an OEM clutch or a stronger aftermarket unit? I know that when I put a "racing" clutch in my old Supra that we also replaced the throw out bearing with a unit up to the challenge. A more powerfull clutch is going to have a lot more pedal pressure, and thus more pressure on that little throw out bearing.
...just a thought...
Old Nov 27, 2002 | 05:00 PM
doink's Avatar
hey man
i had the exact same problem that you do/did. it didnt start until i got my runner home. i took it back to the place i bought it and they put some sort of lube stuff on the bearing and that stopped the squeaking. good luck
Old Nov 27, 2002 | 06:39 PM
DH6twinotter's Avatar
I don't really have an answer to your question, but just wanted to say welcome! Great bunch of folks here.
Have fun.
DH6twinotter
Old Nov 27, 2002 | 07:16 PM
butnut's Avatar
It's all your girlfriends fault! LOL Sure sounds like the throw out bearing...good luck and welcome aboard.
butnut
Old Nov 27, 2002 | 07:24 PM
HBoss's Avatar
No great input for you dude, sorry. Just wanted to welcome you to the boards!
Old Nov 28, 2002 | 01:13 AM
instntset's Avatar
thanks everyone for the welcome....hopefully they will be able to solve the problem this time. I will mention lubing up the bearing to the mechanic....Im just getting tired of being without my truck for 4 or 5 days at a time. Happy thanksgiving :chicken:
Old Nov 28, 2002 | 01:15 AM
instntset's Avatar
I think it was an OEM clutch PhxTRD.
Old Nov 28, 2002 | 03:13 AM
Krash's Avatar
Welcome to the boards. Not a clue what your problem is either just would like to extend a warm welcome. Hopefully someone can get you an answer. My opinion I would take it somewhere else. Unless they keep doing this work every month for free. But even then the time it takes is annoying.
Old Nov 30, 2002 | 10:46 PM
instntset's Avatar
yeah thats the only reason im still going back Krash. All the work has been free since i paid the initial cost....The time I lose for work however is not
Old Dec 1, 2002 | 07:59 AM
growinseed's Avatar
Not sure if your clutch assembly is the same as mine but got the following recommendations from my local toyota dealer:
use a small amout of white litium grease on the clutch fork fulcrum, and the 'clips that hold the fork to the throwout bearing hub, a thin layer of high temp. grease one tranny shaft and where is rides in the pilot bearing. This was followed by "so it won't squeek."
make sure the machanic doesn't use too much or it could sling on the clutch plate and cause slipping.
Old Dec 1, 2002 | 11:26 AM
Cebby's Avatar
Welcome
Sorry, I have an auto - can't help. Welcome to the boards!! Always room for another 2nd Gen Runner owner here!!!
Old Dec 2, 2002 | 02:34 AM
instntset's Avatar
Ill raise my glass to all second gen owners on the board
I am particulary envious of Corey's ride
thanks for the help growinseed...ill mention that also. I am going in next week when I find sometime between my two jobs and class. never enough time in the day
he's gone
7
Dec 3, 2019 07:08 AM
mskalmus
May 28, 2017 07:51 AM
Iceman4193
Aug 28, 2015 08:43 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
PlayAwhile
Jul 20, 2015 11:36 AM
